power steering pump question
Old May 5, 2009 | 09:51 AM
jeff351's Avatar
jeff351
In the process of replacing my leaky power steering pump. Whenever I go to order, they always ask if its metric or standard. What are they talking about?
90 f150 xlt 4X4, 302 auto
Old May 5, 2009 | 11:20 AM
rattosh51's Avatar
rattosh51
Metric or standard bolts holding it on?? Not sure...
Old May 5, 2009 | 02:28 PM
gthbryce's Avatar
gthbryce
my power steering pump is leaking too...damn pumps
Old May 5, 2009 | 02:39 PM
hawgystyle's Avatar
hawgystyle
its the nuts that hold it on i belive, and have you tried to put some power steering sealant in, that fixed all my problems
Old May 5, 2009 | 04:19 PM
Roger T. Pipe's Avatar
Roger T. Pipe
For power steering leaks, try 1 tsp of brake fluid in the res. This works by slightly expanding the seals, thus plugging the leak. I've done this for years and it has never failed me!
Roger
Old May 5, 2009 | 05:19 PM
EPNCSU2006's Avatar
EPNCSU2006
The metric vs. standard refers to the pressure hose fitting, best I can tell. The pump itself should be the same, but I don't know that for sure. I was able to swap hose fittings between my 95 parts engine pump (compression fitting) and my 87 factory pump (o-ring fitting).
Old May 5, 2009 | 05:32 PM
hawgystyle's Avatar
hawgystyle
im gonna try that, im having major problems with mine again
Old May 5, 2009 | 09:48 PM
jeff351's Avatar
jeff351
mine is leaking to the point where the seals are pretty much toasted, so no kind of additive will help. I have to top off the fluid about every 100 miles!
Old May 6, 2009 | 04:39 AM
EPNCSU2006's Avatar
EPNCSU2006
I recently re-sealed my power steering pump with a kit from NAPA. No more leaks....well at least not from the pump or reservoir
barko4
31
Apr 22, 2024 06:55 PM
jlincks
Oct 6, 2014 09:14 PM
pete60hill
Jun 27, 2014 12:37 AM
davbeisner
May 10, 2014 08:53 PM
Bigdoon1522
Apr 12, 2014 09:06 PM
