power steering pump
Old May 10, 2014 | 10:22 AM
davbeisner's Avatar
davbeisner
power steering pump
So my power steering pump is leaking... Tips on replacing it? Haven't even dove in enough to know where it is yet!
Old May 10, 2014 | 07:17 PM
9228.bobcat's Avatar
9228.bobcat
Just wondering how do you know it is the pump that is leaking if you dont know where it is? Not being smart a** just wondering.
Old May 10, 2014 | 07:30 PM
69cj's Avatar
69cj
I have to agree with Bobcat. You have to lift the hood before asking for advice.
Old May 10, 2014 | 07:34 PM
davbeisner's Avatar
davbeisner
FWIW, I've actually done quite a bit of work under the hood of this truck. Just never gone after this particular part yet. I had the truck at the mechanic this morning and they said it was leaking. I've been losing fluid over time, and its been whining bad too, so I knew it was going south... But they want nearly $500 to do the job, and for that money I may just do it myself...
Old May 10, 2014 | 08:27 PM
m-chan68's Avatar
m-chan68
Releasing the tension for the drive belt (look up "the trick" for that one), one 18mm pressure line fitting (an open end crow's foot and suitable extension) and three 10mm bolts later, and the pump is out. You will need a GOOD power steering pump pulley remover/installer tool to remove and transfer the pulley to the new pump (making sure it is completely FLUSH with the shaft after install), and install is just the reverse of removal. Have fun and good luck. The hardest part will be that pressure line fitting.
Old May 10, 2014 | 08:29 PM
davbeisner's Avatar
davbeisner
Thanks for the tips! About how long for an intermediate mechanic?
Old May 10, 2014 | 08:45 PM
m-chan68's Avatar
m-chan68
As mentioned above, the biggest headache will be the pressure line fitting at the pump. That said, as long as you make access to the underside of the vehicle relatively painless, as well as have the right tools handy, you should be good in a couple of hours.
Old May 10, 2014 | 08:53 PM
steelhead2's Avatar
steelhead2
I had to remove my lower radiator hose, and air cleaner ducting to get mine out. It would not go through the bottom. I was able to remove the pressure line after i got mine up to where i could work on it. Remember how the line is twisted when you take it off. Itll need to go back on the same way for when you put the pump back in. Good look, its no piece of cake.
75neuharth
Jan 26, 2017 06:40 PM
Viper1837
Modular V10 (6.8l)
Nov 3, 2004 02:03 PM
bronco cam
1978 - 1996 Big Bronco
Jun 25, 2003 12:21 AM
jdbanks
May 29, 2003 04:06 PM
