289ci power steering pump
Old Oct 5, 2014 | 06:22 PM
jlincks's Avatar
jlincks
Will a power steering pump and bracket from a 69 mustang fit on my 65 289 Galaxy motor that's in my F100?
Old Oct 5, 2014 | 07:07 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by jlincks
Will a power steering pump and bracket from a 69 mustang fit on my 65 289 Galaxie motor that's in my F100?
Originally you said this was a 289 and FMX trans from a 1963 Galaxie.
I corrected you on the trans, saying it was either...depending on where the shift lever was located...a Ford-O-Matic 2 speed or an FX Cruise-O-Matic.
The FMX wasn't introduced until 1969. The original P/S pump is an Eaton, that has its reservoir bolted to the top of it, or remotely mounted on the fender apron with A/C.
The Eaton P/S pump (there are 4 different versions) was installed on 1953/64 FoMoCo Passenger Cars and 1965 Mustang's w/a generator.
Old Oct 5, 2014 | 07:32 PM
jlincks's Avatar
jlincks
Well sorry! The motor is from a 65 galaxy and who's to say it's not an fmx? That's just what I was told was in the truck when I got it. I don't care about all that just need am answer to my power steering pump questions.
Old Oct 6, 2014 | 05:46 AM
NumberDummy
You will care about it if you replace the trans pan gasket and filter. 1965 Galaxie 289 either came w/a C4 (11 trans pan bolt holes) or FX Cruise-O-Matic (14 trans pan bolt holes).
FX/FMX use the same gasket, but the filters are different. C4 gasket and filter are not the same as either the FX or FMX
1965/77 Ford P/S pumps are basically the same, have a steel reservoir. The P/S pressure hose threads onto the pump.
If the '69 Mustang has a 302, its P/S pump mounting brackets will work on the 289.
Is the pump still mounted to the engine, or is it off the car? 1969 Mustang 302's used three P/S mounting brackets, front & rear support brackets and an adjusting bracket.
Old Oct 6, 2014 | 07:05 PM
Roger Carter's Avatar
Roger Carter
The short answer, if you are just interested in the pump fit-up, is that the '69 pump probably will bolt on to a '65 289, as long as the pump in question came off a 302. ('68 was the last year for the 289).
There is no definite answer to your question, due to there being so many variables. As Number Dummy said there are a number of different brackets, pumps, pulleys, etc. that all have to match in order for everything to work correctly. And don't forget that the water pump pulley and the alternator brackets all come into play as well.
Hope this helps.
Old Oct 6, 2014 | 09:14 PM
jlincks's Avatar
jlincks
ok thanks. i have ordered one that come off a 302 and hopefully the pulley is the same as mine. i need to get some bolts for it now though. the one i got doesn't come with any.
54truck
Dec 23, 2014 03:58 PM
yabadaba
Oct 22, 2014 03:50 PM
66RangerinHB
Mar 12, 2014 11:09 PM
kmacht
Sep 15, 2009 09:02 PM
FordF100man
Jan 24, 2008 09:35 PM
