jan '03 Hot Rod hi-po 390 build up
I have a 75 F250 highboy with a np435,np405,4.10's dana 61 rear,44 in front,p/s, p/b,a/c.I have read the article in the Jan 03 issue of hot rod on the 390 fe build up and have decided that was a good place to start to overhaul my plant but I have a few questions.I have read the posts here,consulted a few engine builders,am in the process of reading a few books and so on.I am a NYC firefighter but,I am a heavy truck mechanic by trade.I have decided to use Philidelphia engines for the machine work(referred by Perogie enterprises).
I am going to balance,blueprint the plant.I have an edelbrock performer manifold,crane hydraulic roller cam(p/n349521),harland sharp roller rockers(1.76 ratio)and a set of doug thorley fenderwell headers that i'm going to bolt to cherry bomb 35"x2 1/2" mufflers.and am planning to go to 10.0:1 compression.I want low end torque,but when i step on it on the highway I want it to go.I want it to be streetable,able to sit in heavy traffic for extended periods,but have a little rumble.Few questions,I am planning on going with the edelbrock perfromer heads,any suggestions on the cc size or valve sizes?What cfm carb(650 or 750),should I put a block between the carb/intake to improve torque,what kind of grind on the cam(222/228 duration @.050,.584/604 lift,110 degree LSA).I have never built a perfromance engine before so I don't have a baseline to go off of but,I have done alot of reading and asking questions.Any suggestions,tips,tricks and so on would be greatly appreciated.thanks
Sounds like a solid plan. It's similar to mine which has some *****, even with factory iron heads. Chamber cc size will be dictated by the desired compression ratio, which you stated as 10:1, and the pistons you plan to run. To achieve this ratio with flat top slugs you need about a 72 cc chamber and I wouldn't go any higher tha 10:1 for a dependable street motor. The guys on the FE forum might be a big help to you also.
And BTW, stay away from that Hod Rod crap...
here is a more modern FE build by an FE genius Jay Brown...
Ford 390 FE - Car Craft Magazine
Check it out.
Eagle Specialty Products, Inc. - 2009 Catalog Supplement
It's kind of a pain, you have to flip the pages with the mouse but it's 5 pages in.
Thewarwagon'75
( Scat ) makes a Crank for the ( FE ) , heres a Link >>>>>>>>>>>>>>>
Survival Scat Products
P.S. these ( Scat ) Cranks are not CHEAP !
Wally Womack
Wally Womack
TheWarWagon'75
15
08-27-2011 01:49 PM
TheWarWagon'75
26
05-11-2009 05:36 AM
278broncos
04-19-2004 07:26 AM
sampsin
11-08-2003 03:52 AM
