Need help with intermident wipers
Old May 2, 2009 | 01:37 PM
jeff gammon's Avatar
jeff gammon
Replaced the wiper switch in my 78 f100 with an intermident setup out of an 88 f150. Now my washer pump dosen't work. My old switch has one more terminal in the back of it compared to my new one. What extra wire do I need to run to make my washer pump work? Does it need a ground or what?
Thaks,
Jeff
Old May 2, 2009 | 01:41 PM
460/5's Avatar
460/5
Zombie Survivalist
hey, be glad you even have wipers! mine dont work at all.
Old May 2, 2009 | 01:59 PM
77f2504by4's Avatar
77f2504by4
no extra wires, the 2 plugs on the truck that plug into the wiper switch are all you need. the small plug with 2 wires is where the problem is, just swap the position of the 2 wires and the washers will work!
Old May 2, 2009 | 05:01 PM
1977f250's Avatar
1977f250
Like what 77f2504x4 said. No need to pull out the wires just turn it around = pulg it in backwards. You did hook up the ground wire in the swith right?
Old May 2, 2009 | 07:53 PM
jeff gammon
Yes I hooked up the ground. I will try and switch the 2 wires on the small plug. Thanks for the help guys.
Thanks,
Jeff
Old May 3, 2009 | 12:27 PM
Tees77f150's Avatar
Tees77f150
Thanks,
Jeff
HEY!, Please let us know if this worked for you, thanks!!
Might as well let this thread work for all and be learning experience for all readers.
