Water pump...
Old May 9, 2009 | 06:06 PM
  #31
TurboTuff's Avatar
TurboTuff
Ok I replaced the Plate and put the Fan/Clutch back on as well.
I also put the Shroud back on.
I see where the Thermastat is too so once I'm done with this I'll remove the Alternator and the hose then remove the Mount and replace the Thermastat.
Thanks for everyones help again.
TurboTuff
Old May 9, 2009 | 06:08 PM
  #32
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Did you by any chance put any thread sealant on the WP bolts?
-Enjoy
fh : )_~
Old May 9, 2009 | 06:14 PM
  #33
TurboTuff's Avatar
TurboTuff
Thats funny because for some reason I thought you would say that
So yes I did!
Old May 9, 2009 | 06:16 PM
  #34
TurboTuff's Avatar
TurboTuff
I'm just letting everything sit a bit then I'll top up the coolant.
I don't suppose I'll see a leak until its fired up though.
Old May 9, 2009 | 06:34 PM
  #35
Festus Hagen
Methanoholic
You already filled it??
Thought you were going to do a Tstat at the same time, no sense dumping the coolant twice.
[edit]
Nope, You probably won't till it gets hot!
Unless it's a real bad one...
[/edit]
-Enjoy
fh : )_~
Old May 9, 2009 | 06:59 PM
  #36
TurboTuff's Avatar
TurboTuff
I am
No I didn't fill it with coolant yet..
I have the Alternator off but can see only 1 bolt to remove the Thermastat mount...
the Alternator is bolted to a mount that can be removed with 3 bolts,does this need to be removed to see the 2nd bolt??
Old May 9, 2009 | 07:03 PM
  #37
TurboTuff's Avatar
TurboTuff
I can take a pic but I'd have to hurry...dusk is setting in
Old May 9, 2009 | 07:16 PM
  #38
Festus Hagen
Methanoholic
Unfortunately ... The bracket and all have to come off, Dang engineers!
-Enjoy
fh : )_~
Old May 9, 2009 | 07:41 PM
  #39
TurboTuff's Avatar
TurboTuff
Ok , brackets off,I can now see the other bolt
It looks a little tight..should that back plate or bracket be removed as well??
Old May 9, 2009 | 08:11 PM
  #40
TurboTuff's Avatar
TurboTuff
Ok thermastat housing is off but the hell if that stat wont move ..
Any ideas as it sits flush...oh and BTW the 1 the guy at the Parts Store gave me is too big,not the right 1 so I'd like to remove this 1 without damaging it.Just in case
Old May 9, 2009 | 08:17 PM
  #41
RCrawler's Avatar
RCrawler
Stick a screwdriver through the part that sticks up and pry it out. May be stuck in there with the gasket and a bit of corrosion.
Jason
Old May 9, 2009 | 08:35 PM
  #42
Dave Sponaugle's Avatar
Dave Sponaugle
Thermostat needs to come from Ford or International only.
Old May 9, 2009 | 08:42 PM
  #43
Festus Hagen
Methanoholic
Get one from Ford or IH.
DO NOT use ones from the local chain store! You will regret it so I hear!
It should just pop out.
-Enjoy
fh : )_~
Old May 10, 2009 | 09:01 AM
  #44
TurboTuff's Avatar
TurboTuff
Good morning guys
Well I put everything back together leaving the old Stat in as I need the truck monday morning,and the Ford dealership is closed.
So I will pick up the Stat this week and drain the coolant next weekend and replace the thermastat then.
There was no corrision that I could see and it was working from what I could tell.Was just seated very good.
I'm just getting ready to head out to the shop and replace the coolant and fire it up.
I'll post from out there in a bit.
Old May 10, 2009 | 09:20 AM
  #45
TurboTuff's Avatar
TurboTuff
BTW how many litres coolant my truck take??
