Does anyone have the part number for the rebuild kit for the wire plugs that go into Valve covers, i have some burnt gp pins and i think i am developing some wiring problems for the injectors on one or both injectors for the rear plug on the drivers side. I plan on replacing the valve covers too, so if any one has the part numbers for those i'd like them too.
Ford# F7TZ-14489-BA this is just the tool and shells
check this link out also. i started this post lots of good info on this. i think there is also 2 diff kits, 1 for 97 only and the other for 94-96. you will have to read through it 2 be sure. https://www.ford-trucks.com/forums/7...-kit-part.html
also if you look under tjbeggs sig he has almost a full list of part #'s for every thing.
I got valve cover gaskets with the uvch and the harness with new pins on top for 65 dollars a piece at advance auto. Just replaced week or so ago and worked great.
