Transmission Temp. Sensor
Old Apr 27, 2009 | 10:54 PM
cdiddy's Avatar
cdiddy
Has anyone changed out their transmission temp. sensor? I looked and can not find it on the transmission. Also where can I pick one up at?
Old Apr 28, 2009 | 06:05 AM
ChunderDownUnder's Avatar
ChunderDownUnder
check this link out
picture No. 14
Gauge Installations at DieselManor- 1999-2003 7.3L Powerstroke
Old Apr 28, 2009 | 06:45 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Do you mean the factory trans sensor or what is in the link from our down under buddy?
Old Apr 28, 2009 | 11:17 AM
cdiddy's Avatar
cdiddy
Yes I mean the factory Trans sensor on the trans.
Old Apr 28, 2009 | 11:37 AM
Ponyboychris's Avatar
Ponyboychris
I'm not sure where that one lives. You having issues with it? Quite honestly, it's not much more than a warning light - I say this because I have an aftermarket one and it's 1000x's more accurate.
Old Apr 28, 2009 | 11:40 AM
superduty4x4's Avatar
superduty4x4
Very true- by the time any problem is indicated on the factory gauge it's already too late.
Old Apr 28, 2009 | 01:11 PM
CSIPSD's Avatar
CSIPSD
The factory sensor is buried in the valve body. Your not going to be changing it out very easy...
Old Apr 28, 2009 | 02:05 PM
cdiddy's Avatar
cdiddy
Yes I know it will be to late but I like to have everything working on my truck. When I turn my truck on from being cold the temp gauge jumps to normal temp range on the gauge. Im guessing that would be a bad sensor???
Old Apr 28, 2009 | 05:01 PM
CSIPSD's Avatar
CSIPSD
Hard to say, you would have to pull some codes and run a few tests... The factory gauge is junk anyway.
Old Apr 28, 2009 | 07:44 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If you're talking about the stock gauge, and it's over 50F outside, that's how it works. The gauge will read in the middle of normal anytime the trans temp is between 50F and 230F. That's the way the gauge works, a new sensor won't change it.
Lance4986
Feb 20, 2012 12:24 PM
autoxsteve
Aug 9, 2007 07:31 AM
Edmund
Mar 14, 2006 08:12 PM
twg1966
Jun 15, 2004 02:53 PM
Scouter
May 10, 2004 10:59 AM
