95 Explorer AC Issues
Old Apr 26, 2009 | 01:22 PM
Falcon731's Avatar
Falcon731
Unhappy 95 Explorer AC Issues
Heres a tough question. I just took my truck in to get the AC service, after I just changed the evaporator core. The technician told me that the AC compressor wasn't pumping a lot of AC, the bare minumum. I just changed the AC Compressor a little less than a year ago. Also a new orfice tube, so what could be the problem? The technician thinks it could be a clogged condensor, since my AC Compressor seized up, but the AC system worked fine after that, just had a leak in the evaporator core, that's why that was replaced. So any thoughts or ideas on this issue?
Old Apr 26, 2009 | 07:47 PM
steve(ill)'s Avatar
steve(ill)
you need to know the inlet and outlet pressures of the compressor to figure out if it is full, pumping, or plugged. cant guess at anything without the pressures.
Old May 4, 2009 | 03:50 PM
Falcon731's Avatar
Falcon731
Pressures
I was able to talk to the mechanics that worked on the AC, but they said everything was fine and was able to service the AC. But i've noticed in the days driving it doesn't seem to get that cold. I put a temperature gauge in the vent and the coldest it got was about 60 degrees. But thats with a automatic electronic control which only goes down to 60 degrees. Is that reason or should it get colder?
CB3
Oct 1, 2013 09:48 AM
redsuperduty
76
Jan 3, 2013 10:44 PM
greg_23805
Jun 13, 2011 12:04 AM
jsutton
68
May 14, 2010 08:06 AM
Byron43
Jun 23, 2009 01:01 PM
