My speedo hasnt been working since I bought the truck. I took the the cable off the trans tested it with my cordless drill and it moved the speedo gauge. So I took the Vss out and hooked my drill to the little gear drive, and that moved the gauge too. Where the heck to go from here?
Btw, this is on a 1989 f-450. Any help is appreciated.
Also I searched these forums and never really found anything pertanant.
Should be 2 wires which feed speed info to the cruise control brain.
On second thought, thats how my 87 Ranger is wired.
Does your F-450 have ABS brakes? Or more likely rear only ABS/RABS?
If it does the speed sensor for the RABS might also feed info to the cruise control brain.
Fortunately I bought my 87 Ranger new so I was able to just say hell no i dont want the RABS option.
If you like doing electrical repairs the easy way, you might still be able to buy the 89 F-450 EVTM/electrical & vacuum troubleshooting manual at helminc.com.
Ouch, it looks like the gear inside the trans is broken then.
BTW, I just took a quick look at the wiring diagram for my Ranger & -at least on it- the VSS also feeds speed info to the PCM/powertrain control module.
This is probably one of the inputs the PCM uses to adjust ignition timing & fuel delivery.
