1981 F100 speedometer problems
Old Sep 21, 2014 | 12:09 PM
my996duc1's Avatar
my996duc1
Question 1981 F100 speedometer problems
Took the gauge cluster out and can spin the back of the speedo.... the needle moves.
Drove truck without gauges and cable does not spin.
Unhooked cable at transmission and cable spins on both ends.
Gear is attached at the end of the cable and everything appears fine.
Feeling with a finger in the transmission, the speedo gear inside spins freely.
Should the speedo gear spin freely with the transmission in gear ??
Any ideas ??
_
Old Sep 21, 2014 | 12:45 PM
Gary Lewis's Avatar
Gary Lewis
Speedo gear should not spin if the truck is sitting still. And surely you aren't under ther with your finger on the gear while it is moving.
Old Sep 21, 2014 | 01:23 PM
my996duc1's Avatar
my996duc1
You are correct.... truck not moving.
pulled the cable and felt inside where the transmission gear contacts the cable gear.... gear inside transmission spins freely.
_
Old Sep 21, 2014 | 01:44 PM
Gary Lewis's Avatar
Gary Lewis
Therein lies your problem. If it is a 2wd I'm told you can pull the tailshaft and get to the speedo drive gear. But, I've not done it, so....
Old Sep 22, 2014 | 01:42 PM
my996duc1's Avatar
my996duc1
humm... that doesn't sound like a quick and easy fix like what we were hoping for.
Thank you for the info !
_
93w124
Oct 4, 2020 05:59 AM
LIQUID8
May 8, 2018 12:26 AM
PAwhiteboy
Feb 22, 2017 12:12 PM
KsHighboy
Jan 26, 2017 08:23 PM
Chuck88
Aug 18, 2006 04:29 PM
