Odometer Flashing and blanking out
I have a 06 XL 4x4. Intermittently the odometer keeps going out. Then I will restart the truck and it will be working again. Does not loose mileage. Very intermittent. I checked connections and they seem tight. Can I just swap out the odometer or do I need to swap out the whole instrument cluster. If I do have to swap the cluster can I throw in a Lariat or FX4 cluster and gain stuff or will it not work with my XL wiring. Thanks for any help.
I had an '01 supercrew and the odometer did the same thing. From what i could read it was a cold solder on the panel. Mine would come back on after a while and then i traded it in and got an '08 supercrew. https://www.ford-trucks.com/forums/1...lem-fixed.html try this link as this is what i could find earlier. Hope this helps.
Josh2021
02-21-2010 08:01 PM
