E4OD Help! H E L P P L E A S E ! !
Old Oct 30, 2002 | 10:07 PM
cherron3us's Avatar
cherron3us
I posted earlier on a tranny problem, tranny goes into all gears fine but only foward drive gears I have are 1st, and 2nd. Their are no unusal noises coming from the tranny. Since I Know very little about the tranny I took it to:
1st- Tranny Shop- they said they took the pan down and no gunk in pan, fluid looked great, tested all shift solinoids, and said the PCM was bad.
2nd- Bought a new PCM from autozone put it in same problem?
3rd- took the truck for a second opinion to crown ford, they said theirs nothing wrong with the electrical system, and the tranny is bad? exact words were tranny internal problem.
Who should I trust? I'm into this repair so far over $250
H E L P P L E A S E!!!!!!
Details of everything in earlier posts under cherron3us
Old Oct 31, 2002 | 08:24 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Do you still have reverse? If so I think it could be a stuck shift valve in the valve body.
If reverse is not working, or it's slipping, it is probably a direct clutch failure. But since the first place said there wasn't gunk in the pan, I'm leaning towards the stuck valve.
Saying the PCM is bad is what most places do when they don't have a clue.
Old Oct 31, 2002 | 06:06 PM
jimandmandy's Avatar
jimandmandy
Post E4OD Help! H E L P P L E A S E ! !
Here are the checks that the Ford service manual calls out for "Shift concerns: some or all shifts missing".
Electrical inputs/outputs, wiring harness, PCM
Improper fluid level
Shift linkage or cable - damaged, misadjusted, disconnected
Pump inlet filter/seal assembly - plugged, damaged - filter seal damaged
Main controls - valves stuck, damaged, misassembled
Old Oct 31, 2002 | 09:14 PM
nzabka's Avatar
nzabka
NM3
Jul 19, 2022 08:36 PM
solareclpse2000
Jun 11, 2018 04:21 PM
dunecj2a
Jan 3, 2013 06:09 PM
hotrd3g
64
Feb 28, 2010 08:32 AM
cherron3us
Oct 23, 2002 06:54 PM
