converter drain and fill, help!
Old Nov 1, 2002 | 07:42 PM
cwade3's Avatar
cwade3
im new to fords i know there is a drain plug on my torque converter, 95 ford bronco 302, e4od. i also know it takes 15 to 17 qts to fill the trans and converter was wondering can the fluid be added thru the trans dip stick tube or does the converter have to be pulled and filled. thanks for any help.
Old Nov 2, 2002 | 01:39 AM
charlez's Avatar
charlez
If it has a plug it can be refilled through the dipstick tube. Just don't put it all in at once. Dump in 5-6 qts, start the engine, move the gear selector through all the gears, pausing for a moment in each. (may not engage). Turn off the engine dump in another 5-6, then restart, move through gears, then fill untill full.
Old Nov 2, 2002 | 07:13 AM
cwade3's Avatar
cwade3
thanks for the info charlez!
Old Nov 2, 2002 | 09:07 AM
RoadRash's Avatar
RoadRash
hav24wheel
Mar 6, 2013 01:44 AM
BDalton
13
Jun 28, 2007 10:02 AM
omni
Feb 4, 2005 09:26 AM
omni
Jul 1, 2004 12:56 AM
Schmavic
Apr 14, 2004 01:29 PM
