Radiator additive
Old Apr 23, 2009 | 07:33 PM
PAVEMENTMAN's Avatar
PAVEMENTMAN
Radiator additive
I heard your supposed to add a radiator additive to the antifreeze on a diesel to keep from getting pin holes in the cylinders, I did add an additive but how often are you supposed to add this,
Old Apr 23, 2009 | 07:48 PM
yeldarb82's Avatar
yeldarb82
There is a test strip kit for it ford dosent sell the kit but he told me i could buy it at autozone
Old Apr 23, 2009 | 09:37 PM
joe_13894's Avatar
joe_13894
The local International dealer sells the single pack test strips. They are only good for one year so just buy a few at a time.
The International ones are better since they test both of the additives, and if one is being used up faster you can adjust using the chart. Some of the ones that auto parts stores carry only test for one of the two additives.
Old Apr 23, 2009 | 09:58 PM
flamebuster's Avatar
flamebuster
using distilled water instead of tap water helps too
Old Apr 24, 2009 | 06:33 AM
Cuda_jim's Avatar
Cuda_jim
Well water is a big no-no IMO. It's worse that tap water. I used to use distilled water until I found out about de-ionized water. Most 50/50 coolant come with it.
Old Apr 24, 2009 | 08:37 AM
flamebuster
Jim that is a new one on me. what is the diff. between the two and where do you get it. We use distilled because it has no minerals which I assume includes iron which helps stop electrolesis. also we use napa KOOL additive and water filters with conditioner in filters. I am always interested in new ideas so please share more info. if you can. thanks.
Old Apr 24, 2009 | 11:59 AM
kawa's Avatar
kawa
I also use deionized water in my cooling system. I purchase it by the gallon (my containers) I think I paid somewhere in the neighborhood of $.50 a gallon from an aquarium store.
Rog
Old Apr 24, 2009 | 12:03 PM
Cuda_jim's Avatar
Cuda_jim
I use the 50/50 stuff and the water from my Reverse Osmosis system (RO). My understanding is that RO is the same a s deionized....IDK though.
BocceMon
Apr 20, 2016 03:16 PM
Hossfly05
Feb 20, 2015 09:28 PM
Regulator1988
Jul 22, 2012 02:42 PM
18436572
Jun 20, 2012 08:41 PM
TONKA05'
Mar 9, 2011 03:51 PM
