Fuel additive for injectors?
Old Dec 14, 2014 | 04:29 PM
BocceMon's Avatar
BocceMon
What is suggested to add to gasoline to clean my fuel injectors? I would like to add it to four to five tank fulls just to clean them up a bit.
Old Dec 14, 2014 | 04:47 PM
Evan_P's Avatar
Evan_P
I use B12 Chemtool. I run a can in each tank, run them to empty and refill. Once I have used both tanks I change the fuel filter to remove any contaminats that were lifted out of the tank by the cleaner.
Old Dec 15, 2014 | 10:24 AM
w6pea's Avatar
w6pea
I do the same except, I use Lucas Deep Clean, then I use a container of Lucas Fuel Treatment, works for me.
Old Dec 15, 2014 | 10:29 AM
spacegrass's Avatar
spacegrass
Can't beat Techron. It's not the cheapest, but I run it before every oil change. No complaints here.
Old Dec 15, 2014 | 10:34 AM
rugermack's Avatar
rugermack
I just used Seafoam for the first time, see what happens
Old Dec 15, 2014 | 10:46 AM
John SCB's Avatar
John SCB
Same here. Every 3K. Never had injector problems using this stuff.
Old Dec 15, 2014 | 09:14 PM
eakermeld's Avatar
eakermeld
A quart of OFF ROAD diesel fuel in each tank will do a decent job of cleaning and lubing the injectors. Takes about 4 tanks to get the job done, but you can notice a difference by the 2nd tank. And you cant beat the price, $3.29 a gallon here.
Old Dec 16, 2014 | 07:59 AM
subford's Avatar
subford
Do not add any witches brew to gasoline.
To clean the injectors disable the gasoline fuel system and run the engine on straight 3M fuel injector cleaner keeping the injector cleaner pressure below 39psi (for a V8) with the vacuum line unhooked from the FPR.
Five minutes and they are clean. Has always worked for me.
Old Dec 16, 2014 | 08:33 AM
BocceMon's Avatar
BocceMon
Thank you all for your replies!
Old Apr 20, 2016 | 03:16 PM
Bigcountry66's Avatar
Bigcountry66
Thumbs up
Check out Chris Fix on Youtube he does a comparison of all types of fuel additives for carbon build up and of all the ones I have watched sea foam works the best.
IDIDieselJohn
Mar 19, 2012 11:42 PM
hood
Modular V8 (4.6L, 5.4L)
Apr 4, 2006 08:10 AM
spacekendet
Aerostar
Nov 2, 2005 12:33 AM
JohnAW
20
Oct 12, 2004 02:27 PM
Rusty1
1997 - 2003 F150
Dec 31, 2003 12:37 PM
