1978 - 1996 Big Bronco
Tachometer questions
Old Apr 23, 2009 | 10:27 AM
broncoman80's Avatar
broncoman80
My tachomiter works sporaticly at best on my 1980 bronco 302 does anyone have any ideas? +what hooks to my distributer center plug does this have anything to do with my tach it seys tack test on it "simple questions I currently do not have the answers to."
any help thanks
Old Apr 26, 2009 | 12:46 PM
big bad 79 bronco's Avatar
big bad 79 bronco
your tach gets its signal from the negative side of the coil not sure where it hooks up on the bronco. best thing get aftermarket tach only 4 wires to hook up. my 80 did the same thing ended up being the tach its self
Old May 17, 2009 | 11:13 AM
broncoman80
there is a loose wire on the coil but dont know where it goes as the tack works sometimes and this wire is always completely disconnected i would like to use the original display if possible is there a place to order original parts anybody would reccomend bronco graveyard has all aftermarket bolt on dash style
thaks
wr310rdr
Feb 5, 2014 07:46 PM
jtproudlogger
Jun 11, 2012 05:26 PM
rat49f6
21
Apr 18, 2010 10:59 AM
chriswy
Aug 19, 2007 09:50 AM
gamebore
Jun 18, 2006 11:20 AM
