351 water pump replacement
Old Apr 22, 2009 | 01:13 AM
rough88's Avatar
rough88
Hey guys, figured I would start a thread to guide some attention this way.
I had some bolts break off the wp and I was able to pry the pump itself off. The 2 bolts are still there minus the heads so its just some studs now.
Here is what I am working with,
any ideas?
Old Apr 22, 2009 | 12:57 PM
bashby's Avatar
bashby
They are probably more stuck in the timing cover than the threads in the block. you could try heating the timing cover where the bolts go through, tap the bolt in all directions with a hammer to try to break up the corrosion between the bolt and cover and of course soak it down with PB Blaster. Also tap on the cover where the bolt goes through to try to break things free. I'd plan on replacing the timing cover gasket, it will most likely leak coolant
Old Apr 22, 2009 | 03:06 PM
Beamed's Avatar
Beamed
just soakem real good with pb blaster. try to heatem up a little and get a pair of vice grips.
Old Apr 29, 2009 | 01:35 AM
rough88's Avatar
rough88
Ive Tried all the above mentioned.
No go.
Im thinking Im going to have to drill it out,
Any ideas on how I would go about doing that?
Old Apr 29, 2009 | 12:12 PM
jimg4652's Avatar
jimg4652
Great advice.
You could also try working the studs back and forth. Don't just try to turn them counter-clockwise.
Old Apr 29, 2009 | 12:57 PM
bashby's Avatar
bashby
it will be nearly impossible to drill the bolts out because as soon as the bit walks off center it will get into the softer timing cover and get off the bolt. Its hard enough to drill 1/2" or so without this happening, let alone drilling that far.I'd try more heat and a bigger hammer. You may have to cut the timing cover along the length of the bolts and replace it.
Old Apr 29, 2009 | 01:18 PM
lew52's Avatar
lew52
To drill them you have to get the timing cover off . These bolts ussually seze to the timing cover . You may have to take all the bolts off the cover & knock it off . So the timing cover may need to be replaced .. If you remove the cover look at the chain & gears . If they are worn or have alot of miles on them i would replace them . Good luck this is never an easy job . Lew
Old Apr 29, 2009 | 01:22 PM
jerg_064's Avatar
jerg_064
You could drill into the ends a lil bit and try an oversized EZout hooked up to a breaker bar. Just make sure you don't put any sideways stress on the EZ-out bit, they tend to be brittle. I've broke one off and had to start from square on again on a yoke for the U-joint hold-down bolts.
Old Apr 29, 2009 | 01:32 PM
bashby's Avatar
bashby
you could also use a cutoff wheel and cut through the timing cover and bolt about 1/2" from the block. You should then be able to get the cover off and have enough bolt sticking out of the block to remove them.
Old Apr 29, 2009 | 01:44 PM
lew52's Avatar
lew52
..I agree . After the cover is off i think the bolts will come out . This is a comen problem on the 302 & i guess the 351 ...Lew
quarkdude
24
Nov 8, 2018 12:32 PM
Fox Fader
27
Sep 7, 2016 11:53 AM
snook715
413
Nov 2, 2015 05:36 PM
Sunline Fan
Ford Truck Parts for Sale
373
Jan 29, 2015 09:40 AM
Sunline Fan
Aug 21, 2014 10:20 AM
