fuel pressure
Old Apr 24, 2009 | 09:39 AM
  #31
brickie's Avatar
brickie
Originally Posted by 69cj
The red topped item definitely looks like a solenoid valve for some type of an added shot of gas.
That is a ITP regulated return.
Old Apr 24, 2009 | 10:28 AM
  #32
cartmanea's Avatar
cartmanea
Originally Posted by firefighter33
Is the exhaust no good?Too short or because it flatens out at the ends?What a good exhaust for this setup?
Its fine for running around on the street, but any kind of offroading it hangs down way too low.
Old Apr 24, 2009 | 02:25 PM
  #33
firefighter33's Avatar
firefighter33
got ya cartmanea understood.
As far as the ITP regulated return whats that mean?I can turn up and down my fuel pressure with that.So what im getting at is i want to put a programmer on it sometime but dont know if i can with this setup????
Old Apr 24, 2009 | 03:00 PM
  #34
scameron's Avatar
scameron
i don't think that is a ITP regulated return. unless fuel is feeding the back of the heads. those fuel lines are feeding the front of the heads. besides, ITP uses brass fittings. the fuel lines look correct as in material, but the 90s are anodized. hard to see from the pictures on how the lines are ran.
Old Apr 24, 2009 | 07:45 PM
  #35
firefighter33
While everyone is looking does my truck have the egr delete done?
Old Apr 24, 2009 | 08:13 PM
  #36
brickie's Avatar
brickie
The cooler is still there.
Old Apr 25, 2009 | 02:26 PM
  #37
firefighter33
OK guys i did some taking apart today and found this,the "****" goes to a programmer the INSTIGATOR adjustable 6.0L module made by TS performance.I took it out cause when i turn it up its throws a check engine light and the motor doesnt sound good to me.Everything seems to be running fine no lights.Now i want to know if i can put a SCT on my truck with that fuel regulator thats on it? Thanks for all the help!
Old Apr 25, 2009 | 02:31 PM
  #38
Wyatt66f100's Avatar
Wyatt66f100
fuel pressure depends on where you are tapping into the system at.
Old Apr 25, 2009 | 03:08 PM
  #39
firefighter33
Thats just it im not sure.This is all new to me
Old Apr 26, 2009 | 09:52 AM
  #40
riggz's Avatar
riggz
You can contact them and ask em how it works and if you can remove it.
TS Performance
5425 Nashville Road
Bowling Green, KY 42101
p 270-746-9999
Diesel Performance Specialists
Old Apr 26, 2009 | 10:03 AM
  #41
brickie's Avatar
brickie
Have you opened the coolant bottle and checked to see what else is in there besides coolant.It looks like fuel to me.
Old Apr 26, 2009 | 10:14 AM
  #42
firefighter33
ya there is nothing in there but coolant the outside of the bottle is dirty i guess the coolant is bright green/yellow
Old Apr 26, 2009 | 10:17 AM
  #43
firefighter33
riggz are talking about the fuel regulator or the programmer?I already took the programmer out.
Old Apr 26, 2009 | 06:03 PM
  #44
riggz's Avatar
riggz
the instigator is what i was referring to.
also your coolant shouldn't be green. it should be gold colored. from what ive read, the green coolant can gel up in your system.
Old Apr 27, 2009 | 08:04 PM
  #45
firefighter33
Well i washed the fuel pump off today and found some info it says DDP Diesel Performance Products model#FASS HPFP serial# 02141 tried to look it up found nothing.My luck, also the fuel regulator? says AREOMOTIVE no #'s.I also traced the fuel lines it starts from top of tank to HPFP to the pump on the frame rail under the drivers seat to the engine.
Also what kind of coolant should i use im planning to drain it this summer to put a heater for next winter.
