that looks just like this programer I just put on a buddy's pulling unit. He had an international in it. It didnt do much for him though. It didnt matter how high he turned it up. I think it is supposed to add something like 30% more HP. did you ever see how much psi you are getting on the fuel gauge?
yea i can change fuel psi im running about 55psi right now it was only at 50psi when i bought the truck.Do u know the name of the programmer u put on his truck and is this the same thing?
I cant remeber the name off hand. I will see him this weekend so I will talk to him about it then. It looks like your pyro is mounted after the trubo. That is not the best palce for it unless you are running two pyros you should mount it before the trubo (most put it in the driver side manifold) for a good idea of whats really going on.
If nobody can figure it out try posting those pictures in the 6.0 forum on competitiondiesel.com They should be able to figure out which fuel system that is.
