Hi Guys, I was checking things over under the hood and noticed a solenoid down by the HPOP, the reason I noticed it is because the magnet spacer and nut had come off. I found the parts laying in the manifold valley and reinstalled.
I was just wondering what this solenoids function is....
I did put it back together, I am wondering what is its function???>?
IPR = Injection pressure regulator. Its function is to tell your HPOP how much ICP (Injection control pressure) the PCM is commanding. Basically it fires your injectors.
I agree.. these guys are awesome.. I have learned so much about my truck from the people on FTE. I was in a bind about a month ago after installing my DP Tuner & the help I got was great..
Ive attemtpted to change my glow plug sylinoid on my 2000 7.3. But there are 2 sylinoids which 1 is glow plug? And wat is the other 1? Thanks in advance
Was the rig running ok like this? Sounds like the solenoid stayed in place - that's pretty amazing.
A picture of the IPR in place and the link I pulled it from below:
