Glow Plug relay
Old Nov 6, 2012 | 11:51 PM
NightTrain55's Avatar
NightTrain55
Glow Plug relay
This might be a dumb question...i'm kinda new to these diesels! Where is the Glow Plug Relay on my 97 350? Guy at the store figured fender well; there is a relay there...put the test light on both large terminals (as suggested in the No Start Flowchart) Only lit up one terminal. But then i find another relay that looks the same under center cover beside fuel bowl. I went to move rubber boot from main terminal and it snapped the stud right out of relay!! I'm thinking thats the one?! If so, what is the relay on fender well?
Old Nov 7, 2012 | 05:14 AM
jeffreyt's Avatar
jeffreyt
This is 99-03 forum. Here is a link to the GPR section of the pre super duty powerstrokes. Good luck. I'm pretty sure it's the same GPR that's in our trucks, which means a Napa GPR 109 or a Stancor GPR from RiffRaff. Not sure of the mounting location under the hood.
Old Nov 7, 2012 | 05:20 AM
jeffreyt's Avatar
jeffreyt
Sorry, I guess I didn't completely read your question. On the 99-03 trucks, the GPR is mounted next to the fuel bowl, sounds like you found it. The other relay, i'm not sure. It could be the starter solenoid I guess. We have an air intake heater relay, but it sits next to the GPR. You should get better answers in the 95-97 section.
Old Nov 7, 2012 | 08:04 AM
fordpride's Avatar
fordpride
Starter really is on fender and GPR is next to fuel bowl
Old Nov 7, 2012 | 08:32 AM
MTDewX's Avatar
MTDewX
this is true for sure
Old Nov 7, 2012 | 10:57 AM
yfz 450's Avatar
yfz 450
i went through all this yesterday. my glow plug relay went bad but i have a 2003. on mine there are 2 relays ontop of the motor to the left of the fuel bowl if looking at the engine from the front of the truck. the taller one is the aih relay the shortr one is the glow plug relay. the one on the fender is the starter relay
UP_There's Avatar
UP_There
I think you need a new parts guy!
Old Nov 7, 2012 | 11:57 AM
NightTrain55
Thanks for the replies everyone....and yes, i realized this was the wrong forum after my message was sent!!
cleatus12r
Jan 31, 2022 08:58 PM
Dashriprock1977
84
Feb 1, 2017 08:41 PM
elramosjorge
15
Jan 9, 2017 09:53 AM
liquidlounge
Dec 3, 2014 04:39 AM
NightTrain55
Nov 7, 2012 11:54 AM
