Radius Arm Bushing Load
Old Jan 4, 2010 | 04:02 PM
hav24wheel's Avatar
hav24wheel
I'm going to have to look to be sure, but I think my bushings for one side consist of two metal washers, two bushings, and the spacer. From the FRONT of the truck it goes washer, bushing, spacer the "cup" faces the rear of the vehicle, bracket, bushing, washer, than nut. If my memory serves right. I'll double check when I get home.
Old Jan 4, 2010 | 04:07 PM
hav24wheel's Avatar
hav24wheel
I might have that backwards, might be washer, bushing, bracket, spacer, bushing, washer, nut. It'll be a couple hours before I can look for sure.
CraigK's Avatar
CraigK
I just checked and the spacer only will fit one way. I had it on correctly. I emailed Moog so we'll see what they have to say.
From the front toward the back it goes: Cupped washer facing backward (around the bushing), big bushing, bracket, cupped spacer facing forward, small bushing, flat washer, nut.
Old Jan 6, 2010 | 05:38 PM
CraigK's Avatar
CraigK
Just to followup:
Spoke to a guy at Federal Mogul today. He said that the torque spec is 100 ft. lbs. per Ford and both their black rubber and the thermoplastic blue bushings should be torqued to that spec. He thinks that the spacer I had might have had a defect and he was filing a complaint on my behalf so someone higher up would look to see if there's a quality control issue.
frederic
Jul 16, 2021 09:01 PM
roughridn_sob
Feb 3, 2017 07:30 PM
1browski
18
Feb 7, 2016 12:18 PM
wantahertzdonut
Apr 11, 2015 06:00 PM
Greywolf
Dec 18, 2003 07:46 PM
