Modular V10 (6.8l)
Great oil debate
Old Apr 18, 2009 | 10:30 AM
Bluewater's Avatar
Bluewater
Great oil debate
I have a 2000 excursion, V-10, with 100K Miles on it. Always maintained, always light duty use, a lot of highway miles. Summer towing of a 3,000 lb boat.
Here's the rub. My excursion has used a bit of oil since day 1. The truck was switched to synthetic after break in and have changed oil and filter every 5K, Mobil 1, 5/30. But it is getting to point where she's burnin about a quart every 800 to 1,000 miles. I've done the PCV valve.
I've read a ton about oil on this site and others. I'm considering switching from synthetic to regular oil to see if that reduces the burn. What would you do?
tks.
BlueWater
Old Apr 18, 2009 | 01:34 PM
shadows4's Avatar
shadows4
You can always switch back if it makes no difference. I bought my Ex with 112,000 on it and use it almost exclusively for towing a 9000lbs TT. I use a quart about every 1,000-1500 miles, regular oil.
Old Apr 18, 2009 | 03:15 PM
mikesmayhem's Avatar
mikesmayhem
Switching back to conventional oil isn't going to change the amount of oil you burn. You would be able to save some $ on the extra oil you have been adding. Synthetic is supposed to give added protection but having to add a quart every 800 miles is pretty expensive. I ron AMSOIL synthetic but I don't burn more then a quart every 5000 miles.
Old Apr 18, 2009 | 05:57 PM
Antelope V-10's Avatar
Antelope V-10
Mine burns some too. I think I'm going to try Castrol GTX 5W-20 next change to see if it burns less. Using Motorcraft 5W-20 now.
Old Apr 19, 2009 | 04:54 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Subscribed
What would I do? Run a few changes with plain-jane Castrol GTX 5w30.
Old Apr 20, 2009 | 08:22 PM
Fordfanatic4life's Avatar
Fordfanatic4life
Originally Posted by Krewat
Subscribed
exactly...
u sure its burning it, not leaking it ???
i'd go over that engine bay with a fine tooth comb looking for signs of oil leakage...
Old Apr 22, 2009 | 06:54 PM
69cj's Avatar
69cj
U could also try diff. brands. Walmarts supertech syn. is about 19 buck a gal. I use it in the wifes 06 lexus and have good luck. Just look at api certs on the bottle and don't worry about the name.
Old Apr 22, 2009 | 07:44 PM
eightrac's Avatar
eightrac
I use Super-tech full-syn in everything. At $17 for 5 qts. I can't complain.
BlueWater21
1997 - 2003 F150
Nov 25, 2013 02:50 AM
BlueWater21
Feb 15, 2013 07:24 PM
Bluewater
Jun 26, 2009 07:21 PM
Bluewater
Apr 21, 2009 05:15 AM
Bluewater
Modular V10 (6.8l)
Nov 23, 2004 06:40 AM
