Bouncy speedo?
Old Apr 17, 2009 | 09:38 PM
alconk's Avatar
alconk
Bouncy speedo?
I'm sure this has been covered before but my speedo starts to bounce after 60mph especially around 70. It will vary from 70 to 80 drives me nuts then other days it stays put. The truck has 83K original miles. Do you think it has a wore cable??
Old Apr 17, 2009 | 11:07 PM
crazedfox's Avatar
crazedfox
Try,
__making sure that the cable is fully engaged into the speedo head.
I had the bouncing problem too, just doing this stopped it.
Old Apr 17, 2009 | 11:31 PM
alconk's Avatar
alconk
Already did that but thanks.....
Old Apr 18, 2009 | 12:04 AM
highboy1975's Avatar
highboy1975
try some of the graphite powder lubricant. or, a speedo cable isnt that expensive, just get a new one. it could also be the speedometer itself needs lubed.
Old Apr 18, 2009 | 04:26 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The speedometer itself isn't lubed.
Inside the speedo cable's housing is a woven steel core...it's supposed to be lubed with either graphite or white grease. If white grease is used...use it sparingly.
Another cause could be worn teeth on the plastic DRIVEN speedo gear that's on the end of the cable.
The gears are available from Ford, the most expensive one is $3.47.
Old Apr 18, 2009 | 12:03 PM
alconk's Avatar
alconk
Thank you Bill, I will check the gear.
Old Apr 18, 2009 | 09:05 PM
79F150400M's Avatar
79F150400M
I had that problem. Cured it with a healthy dose of white lithium grease. I took the cable out of the jacket, still on the truck, and sprayed the be-jesus
out of it. re-inserted the cable and no more bouncy. Occasionally, it will act up, but no where near what it was before. Its like I got a whole new speedo cable. Kinda like that hooked on fonics deal.....it werked fer me!! ( no...
really, it did!!!)
Old Apr 18, 2009 | 09:31 PM
alconk's Avatar
alconk
Did you actually leave the jacket in the truck and pulled the cable out like sitting in the cab or did you completely remove the cable assembly from the truck them pulled out the cable??
Old Apr 18, 2009 | 10:40 PM
Ricebird's Avatar
Ricebird
My 79 was doing that at slow speed, put a new cable in and didn't help, took the speedometer out and had lubricated it and cured the problem.
Old Apr 18, 2009 | 11:33 PM
alconk's Avatar
alconk
Where did you lubricate the speedo? I can spin the counterweight freely??
Greg5OH
Jul 13, 2014 03:20 PM
DGMFORD
Sep 23, 2013 10:35 PM
rickfixit
May 23, 2007 10:54 AM
ken selvy
Aug 30, 2006 03:07 PM
RaleighDad66
21
Mar 31, 2005 02:24 PM
