Sponsored by: Real Truck
speed sensor, how do they work?
Old Jul 10, 2014 | 11:04 AM
Greg5OH's Avatar
Greg5OH
Im putting an 05 10.5" under my 91. It has a speedo gear driven speedo. Long story short the speedo gear got stripped and I got no speedo.
If i purchase an electric speedo, can i simply hook it up and feed it the signal from stock speed sensor?
Never dealt with electronic speedos before.
Old Jul 12, 2014 | 07:36 PM
TexasRebel's Avatar
TexasRebel
An electronic speedometer will need a hall effect sensor and a tone ring to provide a signal that relates to speed. A speedometer gear will not suffice.
Old Jul 12, 2014 | 08:18 PM
EXv10's Avatar
EXv10
Nope, it's either all the one or all the other system. The new tone ring will have to just go along for the ride.
Old Jul 12, 2014 | 09:04 PM
Greg5OH's Avatar
Greg5OH
What i mean is, can i use the speed sensor that is inthw rear end, and relay that signal to an aftermarket electronic speedometer? i believ the sensor in the rear end housing is a hall effect as there is a tone ring rotating below it.
Old Jul 12, 2014 | 09:55 PM
EXv10's Avatar
EXv10
I don't know but I doubt it and maybe some more knowledgeable will chime in. They didn't have tone rings etc when I was working on cars. That ring is the only major change on rear ends in at least 40 years.
Old Jul 13, 2014 | 12:26 AM
Yahiko's Avatar
Yahiko
The tone ring sits between the carrier and the ring gear.
The hall effect sticks into the case from above.
The PCM reads a signal that looks like this
Hall Effect sensor on scope
Sean
Old Jul 13, 2014 | 12:52 AM
EXv10's Avatar
EXv10
Sean
We know that.
Old Jul 13, 2014 | 02:56 AM
Yahiko's Avatar
Yahiko
The signal from the sensor needs an intermediate device to
convert it so that the display can show it on an analog type
dial. Also in the case of the newer clusters they are all digital
and have something like a stepper motor that can be commanded to
a given degree position. If you already have a cable drive speedometer
it would be less work to repair that and not to convert it.
As the speed of travel goes up the pulse will narrow and increase
in frequency. The PCM takes this and turns in into digital that is
passed to the cluster and the cluster controls the position of the
needle of the indicator in relation to the speed.
Sean
Old Jul 13, 2014 | 10:14 AM
EXv10's Avatar
EXv10
Yea I figured it went through a computer module dedicated to a newer truck so he will have to stick to the old system.
Old Jul 13, 2014 | 01:54 PM
TexasRebel's Avatar
TexasRebel
yep. The processor translates the frequency of the tone ring (Hz) into a speed (MPH) then provides an output (pwm) that corresponds with the correct angle on the needle.
The processor could be bypassed where the tone ring is the PWM signal, but you would have to design an excitation board to power both sensor and actuator as well as a signal modifier to make the hall effect sensor output become the servo input.
The old gear and cable use eddy currents and calibrated spring... nothing swaps over.
Old Jul 13, 2014 | 03:20 PM
Yahiko's Avatar
Yahiko
One thing about the digital system dash is the airbag box aka black box
can grab a freeze frame of all the data like brake on or off and what
speed your going.
Sean
S7AN
Jun 14, 2018 03:03 PM
ExplorerTominCO
Oct 2, 2017 07:20 PM
Nick1911
32
Aug 23, 2008 10:01 PM
Tailhunter18
Nov 18, 2004 10:58 AM
