c6 differences
Old Apr 16, 2009 | 10:59 PM
smoke n tires's Avatar
smoke n tires
c6 differences
trans experts please tell me the difference in the 76 and newer c6 versus the older than 76 ones. i have a 78 and i have another one that i dont know what its out of. the one i have has spines cast into the top of the bellhousing area where the 78 doesnt. are their major differences inside? i have the tag, where can i cross the numbers? i guess if its like ford engine components the tag should tell the year.
Old Apr 17, 2009 | 03:10 PM
mark a.'s Avatar
mark a.
What are you wanting to do ?
Old Apr 18, 2009 | 01:59 PM
rclarke's Avatar
rclarke
The friction material and clutch plates are different. I think I remember some thrust bearings and planet assemblies may be different. Before May 1976 used type F fluid and after use Dexron/Mercon.
Old Apr 18, 2009 | 05:55 PM
archangel's Avatar
archangel
The semi-metallic friction plates (they look black) use type F, the others that use the paper frictions (they look light brown and obviously paper) use the Dexron/Mercon.
The C6 went through various upgrades throughout the years ranging from case castings to the internal components, and some parts can not be mixed as they will not fit or work.
I preferred the Semi-metallic as I believe they can handle the heat a little better than the paper.
ungerp
26
Dec 5, 2021 03:24 AM
bigdaddys76
Dec 21, 2010 08:18 PM
ferrwrench
Jan 22, 2008 08:07 PM
terron78b
Jun 8, 2007 11:06 PM
fordguy76
Feb 5, 2002 07:27 PM
