I wonder if that battery is still down a bit from the running on the starter even after the trickle charger, so the system is still drawing amps to charge it from the alternator?
That very well could be. I have seen readings high from a low battery, also have seen some low readings with low batteries (my 2005 powerstroke 6.0 falls into that category)
