HOT HUBS!
Old Dec 12, 2002 | 06:47 PM
motobub's Avatar
motobub
HOT HUBS!
I drove about 5 miles today and then got out to lock my hubs in to go muddin', and man they were hot! Why are they so hot, is it from the brakes? It was some stop and go traffic. Maybe the axle is spinning all the time? Which would mean that when I lock or unlock my hub it doesn't change anything, right?
Please Help,
Thanks
Lars
Old Dec 12, 2002 | 07:22 PM
jalampi's Avatar
jalampi
HOT HUBS!
Its your brakes.
1997 F350 PowerStroke,5 Speed, 4X4,36 Inch Buck Shot Mudders, Strait Piped, Chiped, Propane Injected, LUK Clutch, Reverse Shackle Kit
Old Dec 12, 2002 | 07:43 PM
flyboy2610's Avatar
flyboy2610
HOT HUBS!
Do your wheel bearings have plenty of grease?
Old Dec 13, 2002 | 07:19 AM
DoubleA's Avatar
DoubleA
HOT HUBS!
My suggestion would be to check the bearings.
If you mud alot very good idea to re-grease them bearings afterwards.
I used to go alot, and learned a lesson after swamping my F250.
got water in the bearings and they rusted, then going down the road the one front tire locked up, and that was with 39's.
before it locked up, I knew something was funny, I stopped and felt the hubs and they were very hot. I thought the hub was going out and engaging the axle, but it was the bearings. I missed out on a great motorcycle ride because of it.
Old Dec 13, 2002 | 09:17 PM
motobub's Avatar
motobub
HOT HUBS!
I needed new bearings. Put them in and now the front tires are hard to turn by hand. Do you think I packed the bearings too full of grease and now it has to work its way out?
Thanks
Old Dec 14, 2002 | 10:08 AM
flyboy2610's Avatar
flyboy2610
HOT HUBS!
You may have put the bearing nut on too tight. Back it off one notch at a time until your tires turn freely, then put the cotter key in.
Old Dec 15, 2002 | 09:05 PM
motobub's Avatar
motobub
HOT HUBS!
It is still producing lots of heat. I can back the nut off any more because it is right on the edge of tight and where it is losse. I think it might be my brakes draggin, but don't know how to goabout fixing it.
I need to get this fixed fast because it is my daily driver.
Tahnks
Lars
Old Dec 15, 2002 | 09:15 PM
91f250460's Avatar
91f250460
HOT HUBS!
Get a Haynes manual. The torqueing sequence for the front bearings is an exact measurement. If they are not torqued properly you will be replacing them again very soon. I found this out the hard way, the first time I replaced them I did it like I would any other vehicle, tightened them and then backed the nut off until wheel would spin free with no wobble. Lasted 5000 miles. The second time I checked the manual and torqued them, that was 20,000 ago no problem. However it is winter service time so I will regrease/pack and reinstall them. I don't know if being a 4x4 makes the difference, but they are finicky. Hope this helps,good luck.
T. Roberts
UFD Local 1147
Old Dec 16, 2002 | 05:39 AM
mathelm's Avatar
mathelm
HOT HUBS!
Sorry if I missed it, but what make model truck is it? Someone here should be able to give you the torque sequence.
Old Dec 16, 2002 | 07:55 AM
Ford_Six's Avatar
Ford_Six
HOT HUBS!
TchTchr
Feb 21, 2014 04:24 PM
PSDlongbox
Mar 2, 2013 11:30 AM
Fishin76
Dec 7, 2010 10:53 PM
RhinoScores
1978 - 1996 Big Bronco
Sep 23, 2006 09:29 PM
dinty01
Apr 2, 2006 08:50 PM
