1978 - 1996 Big Bronco
Wheel Hubs - Hot?
Old Sep 23, 2006 | 05:31 PM
RhinoScores's Avatar
RhinoScores
Question Wheel Hubs - Hot?
I just finished putting new wheel bearings, rotor/hub and brakes on both the front of my 94 Bronco. After test driving, I noticed the auto-lock covers are extremely hot. They would burn your hand if you held it longer than a few seconds. Is this normal or did I do something wrong?
Old Sep 23, 2006 | 06:03 PM
kameronth's Avatar
kameronth
I am prety sure that it is normal. They just get hot from the brakes and spinning. I would not be concerned about it.
Old Sep 23, 2006 | 07:01 PM
MinnManBroncoFan's Avatar
MinnManBroncoFan
You might have a stuck caliper the was the inside of your pads wore more then your outside ones ?
Old Sep 23, 2006 | 07:02 PM
RhinoScores
Thanks. Now I'll be looking for a Bronco to pull into a parking lot and wait for the driver to walk away so I can go feel the hubs.
Old Sep 23, 2006 | 07:06 PM
dwoodler's Avatar
dwoodler
I would! The hubs should only be HOT! if you braked for an extremely long period of time. The hubs should be warm but never hot enough that they would burn you, IMO. Over tightening of the wheel bearings will cause the hubs to get hot too. They torque required for the wheel bearings is only the weight of your ratchet being pushed and released from midpoint and letting it swing down (and not with a big widn up either!) The inner nut only has to keep the bearings from having any movement when you grab the rotor at the top and bottom and rock it. It's better to be too loose and have a little motion and have to tighten it a little more than to over tighten it. Overtightening will lead to premature bearing failure.
RhinoScores
Calipers, pads, rotors and all hardware are new, as are the wheel bearings. The only used parts of the autolocking hub that the previous owner put on it. By the way, the autohubs are different models from each other. One has three torx screws in the cap and the other has five. The guts are totally different also. I may have to go get some Warn locking hubs.
Old Sep 23, 2006 | 07:45 PM
b4hntn's Avatar
b4hntn
I know many are moaning when auto hubs are mentioned....I still have them also. For you to compare, when I have been on the highway in Texas Summer and stop at six traffic lights before reaching home I have felt the auto hubs upon arrival. They are hot but not like a grill lid with three seconds max touch. If I really wanted to I could continue touching the hubs for a long time. It would be painful but may not burn. Last serviced about 100k ago.
Old Sep 23, 2006 | 09:29 PM
fishin machine's Avatar
fishin machine
I'd check it out, no way should your huds be that hot. If just one side I'd think you'd have a caliper hung. Is it both sides, if so I'd bet you torqued the bearings down to far. The chances of you having both calipers hung is slim, but both bearings to tight, better. I don't see the auto hubs causing that, but personaly I'd get a set of matching huds and used the mismatches as spares.
MTGunner
23
Dec 27, 2014 06:20 PM
TchTchr
Feb 21, 2014 04:24 PM
Groundpounder0331
13
May 25, 2010 09:32 AM
79F-350
Apr 10, 2010 06:18 PM
VIBR8R
Jul 10, 2003 02:30 PM
