axel code 39??
Old Apr 12, 2009 | 01:01 PM
pmelah's Avatar
pmelah
axel code 39??
can anyone tell me what axle code 39 is what gears i would have that is all i can find on the vin sticker in the door jam its a 94 F250 7.3 IDI truck was manufactured 11/93 thanks for yalls help
Old Apr 12, 2009 | 02:40 PM
KJLYPW's Avatar
KJLYPW
As per my 93 owners guide, rear axlee code 39 is Ford axle, 3.55 gear ratio
Old Apr 12, 2009 | 02:42 PM
fuzzy1626's Avatar
fuzzy1626
Axle code 39 is a 6250 lb. cap. 3.55 non limited-slip.
Old Apr 12, 2009 | 02:46 PM
pmelah's Avatar
pmelah
thanks KJYPW i bought my truck used back in Aug. and it did not come with the owners guide i need to order one and there is no big call for these trucks in junk yards i use to work at one and i only seen one in are yard in the 5 yrs i worked there
Old Apr 12, 2009 | 02:48 PM
pmelah's Avatar
pmelah
thanks fuzzy i did not know or think about the weight rate i figured itwould be limited slip
Old Apr 12, 2009 | 02:55 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Since 1959:
If the AXLE code listed on Certification Labels (or Warranty Plates) begins with a letter: Limited Slip.
If the AXLE code begins with a number = No Limited Slip.
1959 was the first year Ford offered Limited Slip.
Old Apr 12, 2009 | 03:02 PM
pmelah's Avatar
pmelah
would anyone know what the speedo would be off by with 265/75r16 tires with 3.55 rears not real knowledgeable on the math factory calls for 235/75r16
Old Apr 12, 2009 | 03:03 PM
pmelah's Avatar
pmelah
i will check to see if it has a letter or a # brb
Old Apr 12, 2009 | 03:11 PM
pmelah's Avatar
pmelah
my axle code is # only so no limited slip my F150 has code 19 no letters
Old Apr 12, 2009 | 03:14 PM
fuzzy1626's Avatar
fuzzy1626
That would be 3800 lb 3.55
Old Apr 12, 2009 | 03:15 PM
Dean88's Avatar
Dean88
The speedo should still be fine, cuz your truck should have to came with 235/85's from the factory, and the 265/75 are the same size as the 235/85's they are just wider.
Old Apr 12, 2009 | 03:24 PM
pmelah's Avatar
pmelah
sorry 235/85r16 thanks dean88 i did not know the difference in tire size one thing i havent learned yet
Old Apr 12, 2009 | 03:43 PM
Dean88's Avatar
Dean88
Here's a decent article about how to breakdown gears and tire sizes.
Old Apr 12, 2009 | 08:34 PM
Dodge/Cummins's Avatar
Dodge/Cummins
My '94 has 3:55s and 265/75R16s and the speedo is almost perfect measuring it against 10 mile markers and my GPS.
deanzawistowski
Dec 10, 2019 03:29 PM
Coldair460
Oct 13, 2012 03:28 PM
jkidd_39
17
Aug 3, 2012 09:09 PM
race39
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Apr 3, 2011 08:11 AM
boggerted
Apr 7, 2009 12:15 PM
