92 explorer eb a4ld
Old Dec 28, 2002 | 02:44 PM
boutnyhuntyr's Avatar
boutnyhuntyr
92 explorer eb a4ld
i have a 92 eddie baur explorer automatic 4x4 and it recently started holding 1st and 2nd gear to the red line ...drive and od pull great . it is not slipping , just will not shift out to the next gear . also ....when stopping i can feel it "give " when below ie. 8 mph .... am i going to get out cheap with a modulator valve or am i going to have to dig deep and rebuild ??? please help me
Old Dec 29, 2002 | 03:56 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
92 explorer eb a4ld
Most likely it is a sticky governor, not the modulator. The governor isn't much harder to get to, and usually a good cleaning can fix it.
How old it the transmission fluid? Old gunked up fluid causes problems like this.
Old Dec 29, 2002 | 06:00 PM
boutnyhuntyr
92 explorer eb a4ld
tranny fluid is only a couple of months old ...did a flush and then a filter /fluid change . ran fine until just a few days ago . started when the cold snap hit here in the south ....when it started getting really cold started holding 1st gear ...but then it started doing the same in second ...tranny fluid is still bright red and doesnt smell burnt ... where can i find more info on tthe governor...trouble shooting it and location ...thanks for the help
Old Dec 30, 2002 | 08:55 AM
tomw's Avatar
tomw
92 explorer eb a4ld
Get the book at http://www.atsgmiami.com/ Cost about $25 or so. Also have an 'updated and improved parts & modifications' book listing improved parts and mods... JCWhitney sells the book too.
Governor is in the tail housing on the output shaft. Would have to remove the tail housing to get to it. It then unbolts to disassemble & clean.
tom
Old Dec 30, 2002 | 09:10 AM
Opera House Works's Avatar
Opera House Works
92 explorer eb a4ld
[updated:LAST EDITED ON 30-Dec-02 AT 10:12 AM (EST)]governor would just be first. Though governor is probably sticking a little at this age. You can pull it out and polish it. I certainly recommend everyone getting an ATSG manual for this transmission. Manual only $16 at bulkpart.com and the upgrade book is the same price but not really needed. Modulator is only $12 and SPX filter $10 there too. Shipping charge stays at $7.50. If you get adventurous you ought to do the low/reverse servo upgrade. Some say the easiest way to the modulator is through the carpet.
Old Dec 31, 2002 | 01:20 AM
boutnyhuntyr
92 explorer eb a4ld
vacuum modulator replaced today after slitting my wrist .....runs great now ...thanks for the help
Old Dec 31, 2002 | 07:59 AM
dumontkid's Avatar
dumontkid
92 explorer eb a4ld
DimitriesDream
Bronco II
May 27, 2013 08:47 AM
Hb Fabrications
Mar 3, 2009 10:46 AM
bigben4x
Dec 9, 2006 04:15 PM
sc 4x4
Oct 5, 2002 04:24 PM
