Some have the whole gearing concept backwards. Running the higher ratio in the axles (nemerically lower) and compensating with a low transmission gear is not the direction you want to go.
The entire reason for a lower first gear in the trans is not to make up for larger tires or a lack of mechanical advantage in the axles. This is to aid in the motivation of the vehicle under severe loads, not the other way around.
Overdrive is there so that engine RPM's can be lowered without compromising bottom end grunt while still maintaining a reasonable highway speed.
have24wheel has the right concept and more gear in the axles is never as much of a problem as not enough when we throw the off road factor in there.
If you are after mileage, then slow down. A 100 mile trip at 70 miles per hour takes a given amount of time, and that same 100 mile trip at 65 miles per hour takes about 6 minutes more. 6 miutes. WHich one will get the better mleage? Point is that you dont have to sacrifice mileage by installing a set of gears with a better than optimum ratio. More aggressive can do as well or better than the conservative highway ratios.
This is part of the reason we dont see large haulers with highway ratios like a 2.75 or something silly like that.
Ill take 4.56 gears and 35 inch tires all day long, (with a three speed auto) but the 4.88 option with an overdrive is awesome. Easier on the trans, easier on the entire drivetrain, and so much better off road. Gear reduction provides some real crazy traction and most guys that state "my stock gears are fine, even with large tires" has probably never driven a similar vehicle with a deep set of gears. (numerically higher).
Horsepower is somthing that can offset this combo, however, it is only compesation. Meaning that more horsepower and this mechanical advantage will create an even more potent combo. Dont shy away from steep gears like the 4.56, or even the 4.88. If you upgrade the trans, and keep a decent overdrive, then gear it to the moon. You will enjoy a more capable off road rig that has nice street manners.
Keep in mind that the small axles will not like the added power, nor will it take kindly to the added stress so keep that in mind when considering steep gears for the smaller axles.
Most of us that have would never go back to the terrible ratios that are being considered, or at least discussed.
I like how no one questions what you say, its like a church congregation listening to a preacher.
Ed isn't a preacher. Ed is GOD.
It just seems that whenever I have a question, Ed always gives me the best, most straightforeward answer. I have no reason to question his experience lol.
I'm sure if he said that stacking blocks was a good idea we'd probably assume he's right.
Its only because I tend to use some fancy pants words, and it keeps most folks guessin, or my replies are so dang long they got tired of reading half way through. Perhaps, nobody wants to reply back because they fear I might type even more than I already do, lol.
But for the mostpart I like to read what you have to say. Usually get some good information out of you.
You should learn to hit enter once inawhile so things arn't so spaced though lol.
Ill take that into consideration, though I do have to tell you that most of my replies are from my Blackberry.
Often times it is difficult to produce proper paragraphs.
as of now they are getting installed tomorrow while im at work...but ive heard that before...ill believe it when they drop my truck off at the shop
you misunderstood me...im not trying to make MPG by keeping the 3.55s...i have to keep them because i havent the cash to regear at the moment...so they will have to work for now regardless...i was just meaning that it might make some MPG while at highway speed...although it will suck up my low end grunt...gears should only be changed to keep the overal ratio the same when tires get bigger, not to compensate for engin power tranny ratios or MPG...
big rigs run the same gearing as most pick ups do...anywhere from the 2.72 (the highest ive seen) to about 4.11 i think... then you get the CP rail trucks that drive up on the tracks and pull up to ten fully loaded rail car at once...they are geared to the moon...they also have ZF trannys, ZF payloader trannys to be exact
You don't always want the overall ratio the same. As you up the tire size, the wt. of the tire and wheel increases. Witch takes more power to turn, so if you want it to "feel" the same when you drive it, you would need a overall ratio a small % lower than stock. Yes you can use gears to compinsate for power. Why do you think big rigs have 10 and higher speed trannys. Gears. Why do you think guys can run 4 bangers with 42s. Gears. They run doublers and low gears in the axles, so they can have power to the tires. If you "power out" at around 50 mph now with your "little" tires, I would suggest getting some 4.88s for your 35s. With the lower gears, you will get better milage and it will have more power to the ground.
That must go along with the greatest lines in history, much like "the check's in the mail", or "I promise to pull out", or ......
they arent on but it was my fault this time...they arrived at about 3:30-4:00 and i was at work and i had to do an oil change and stuff on the truck between then an 6:00 so i didnt want them taking my truck cause that had to be done...but this time i know they are here...i saw them and i was on them like a fat kid on a chocolate bar LOL...gonna go get em put on tomorrow sometime...PICS SOON!!!!!!!
overall or actual ratio is affected by tire size eg. going from 31's to 35's keeping the 3.55 gears my actual ratio goes from 3.55 down to 3.14 just by changing the tires...changing gears to get that back to 3.55 is the idea...and i guess if you were to go way up to 38 or more you would want even deeper gears to make the actual ratio lower...most over the road big rigs are 13, 15, or 18 speed trannys, the engines in these trucks are governed at 2200 RPM, no big rig engine will rev over that unless it has been tampered with... the reason for the 18 gears? have you ever shifted one? the gears are incredibly close together, not to compensate for power it is to keep the shift points at lower RPM (the bottom gears are usually shifted between 1000 and 1200 RPM) to lessen the strain on the rest of the drivetrain...as i said the rear end gears in the big rigs are about the same as the ones in most pick ups...more stockish pick ups anyway...
