You are a good friend and a terrible friend at the same time.
I agree with that statement. The 1st night my truck wouldn't start while I was installing my DP Tuner, it was almost 3 am & I was on here looking for answers & Clay was PM'ing me, giving me suggestions to try.
Is there any answer as to where the best place is for the pyro?
The preferred method is pre-turbo. It gives a more accurate reading, as it is closer to the block and gives the exhaust gas less time to cool before being read. It takes the guess work out of knowing how hot the pistons are getting.
Isspros and Autometer seem to be the ones now, I heard in another thread the Dipricols, they arn't going to make anymore, forgot about the reason why. Don't hold me to it though, guys on here had NO problems with them.
I was wondering more about the difference in temps between pre and post turbo location.
There is no direct anwser. It can be nothing at idle to as much as 500* at WOT pulling a load. There is only one correct place to put a pyro probe on a PSD... Pre turbo.
In the manifold or in the up pipe is up to you, but pre turbo is the only location.
Would you consider it useful to have both so you can compare them and see how much heat your engine is absorbing?
