Upper fuel filter question...
Old Apr 10, 2009 | 10:03 AM
basstardo's Avatar
basstardo
On my old 7.3, when I changed the fuel filter, I would fill the bowl up with Stanadyne for a little shot of extra cleaning for the injectors. I got that idea from the folks in the 7.3 forum, and it was something I did ever time I changed it. Does anyone do that with the 6.0? Just wondering if it's worth it since the upper fuel bowl is so much smaller than the filter bowl for the 7.3.
Old Apr 10, 2009 | 10:40 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
I've heard a lot of folks do this with the 6.0 also......
Old Apr 10, 2009 | 10:59 AM
bradcollison's Avatar
bradcollison
I fill mine up with Stanadyne too. Works for me!
Old Apr 10, 2009 | 11:00 AM
cartmanea's Avatar
cartmanea
There's really no point since most of it will go through the regulator and back to the tank. You're supposed to cycle the key three times before starting to remove air and that will remove most of the cleaner also.
Old Apr 10, 2009 | 07:35 PM
texan2004's Avatar
texan2004
I've never done this one mine. Cartmanea is probably right but it will make it through the injectos at some point and you will get a higher concetration initially than if you introduced it at the tank.
BTW - where are you in "Newpert News". I grew up there.
Old Apr 11, 2009 | 04:18 AM
RigET's Avatar
RigET
I filled my upper filter bowl with Diesel Kleen last time I changed filters and 10 miles later the truck crapped out. My EGR was clogged in the open position by carbon, could this be related?
Old Apr 11, 2009 | 08:16 AM
69cj's Avatar
69cj
If it cycles back to the tank it is not anymore concentrated than adding it to the tank!!
Old Apr 11, 2009 | 08:24 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
Coincidence
Old Apr 11, 2009 | 12:11 PM
texan2004's Avatar
texan2004
I may be incorrect but I do not think it all cylces back to the tank.
xxfalconerxx
Nov 17, 2011 09:52 PM
baconmobile
17
Jan 23, 2011 07:50 AM
kkdad7.3
13
Oct 22, 2007 03:20 PM
Tailspin
Feb 22, 2007 02:17 AM
