Sponsored by: Real Truck
light bulb replacement in dash
Old Apr 10, 2009 | 08:10 AM
Downriver Thunder's Avatar
Downriver Thunder
I have a few bulbs out in my cluster, 05 F250. What's involved in removing the cluster to change them? I do have ESOF but don't know if the switch is attached to the panel or the dash itself. I have to replace the ESOF switch also due to the light no longer working.
Old Apr 10, 2009 | 10:39 AM
1975StroppeBaja's Avatar
1975StroppeBaja
This may not even be relevant since you have an '05, but here's some info I put together about these things with my '04.
If the 4x4 switch is the same, you can replace the bulb, it just takes a little soldering.
HTH.
Article covering all dash lights....
2004 F250 LED Dash Lighting
Article specific to the 4x4 switch...
2004 F250 Dash Light Bulbs
rechinca
Sep 17, 2016 12:06 PM
james734
Nov 9, 2014 09:36 AM
85AustinTucker
Nov 4, 2013 07:48 PM
Kamstutz
40
Feb 10, 2013 10:07 AM
rob7.3
Dec 1, 2011 04:00 AM
