2" Autospring - Alignment
Apr 8, 2009 | 07:08 PM
After putting a 2" Autospring leveling kit on a Scab, has anyone needed to replace the factory alignment cams before alignment could be done?
Apr 8, 2009 | 07:27 PM
No I didn't have to replace anything. Just got an allignment done.
Apr 9, 2009 | 12:25 AM
cams for caster/camber, no need to replace
what did your shop say?
Apr 9, 2009 | 01:07 AM
The shop that will install the 2" AS will do the alignment. They said with these trucks they sometimes need to put in a ~$300 ?caster/camber kit? (I think) to get the adjustment needed to bring it back in spec.
They will try the alignment without it first and it may not even be an issue. It's just something I never even considered until now.
Apr 9, 2009 | 06:25 AM
we put is a 3" skyjacker kit here and never had to install anything.
Apr 9, 2009 | 07:08 AM
No they shouldn't have to do anything like that, and if they tell you they do it might be time to find a new shop.
Apr 9, 2009 | 09:56 AM
If the caster/camber is out and you dont have the cams
the only thing they can do is toe in/out
Apr 9, 2009 | 01:35 PM
That's good because I should only need toe-in adjusted after the leveling kit.
thanks
LHGrizzly
2009 - 2014 F150
Dec 22, 2012 08:15 AM
edub32
2004 - 2008 F150
30
Apr 2, 2010 10:31 PM
beernutz09
2004 - 2008 F150
18
Feb 16, 2009 01:11 PM
wreedZ71
2004 - 2008 F150
15
May 19, 2008 04:56 PM
littletoy94
2004 - 2008 F150
Jul 29, 2007 02:48 PM
