6637 question
Old Apr 14, 2009 | 06:20 PM
  #136
Izzy351's Avatar
Izzy351
I agree. This one probably made the most sense out of any other explanation of this. You might've even convinced me. BUT most "other" folks in the know says Ford did it because customers were complaining about turbo noise. Maybe it was both situations. Don't know that we'll ever find out.
Also, the "stuff" under the Ford insulation isn't spray-on. It's fiberglass. Have a look -- this is what was under mine when I pulled it off:
Old Apr 14, 2009 | 06:51 PM
  #137
mechelement's Avatar
mechelement
If it's a thermodynamic issue, could you just ceramic coat the tube after removing the foil and obtain the same, if not better, thermodynamic properties?
Old Apr 14, 2009 | 10:27 PM
  #138
white Buffalo's Avatar
white Buffalo
Originally Posted by ernesteugene
You also need to operate an engine for 2 or 3 minutes at sustained boosts of 22 psi and higher before the "heat capacity" of the intercooler saturates and you get the maximum "steady state" MAT reading. During Tenn's measurements he was towing his boat and he had his ATV in the bed of his truck so that he could put a higher load on his engine but he was in traffic on the interstate and had to lag back to leave a gap then do a relatively short acceleration run at high boost and then let off the throttle.
If you look at Tenn's data table you'll see his measurements such as a MAT of 129 F when his measured IAT was 145 F and you'll see my computer model corrections (in blue) of his 129 F MAT measurement to a corrected "steady state" MAT of 166 F to 169 F which is the "steady state" MAT reading Tenn would've measured if he could've maintained his high boost run for 2 or 3 minutes such as when towing up a long grade. But I'll have more to say about this later.
So in order for the 6637 to be an issue (injesting hot intake temps) you need to run 2 or 3 minutes at sustained boosts of 22 psi and higher? Do I understand this correctly?
"You need to operate an engine for 2 or 3 minutes at sustained boosts of 22 psi and higher before the "heat capacity" of the intercooler saturates and you get the maximum "steady state" MAT reading."
OK Gene, Mike was pulling what, maybee 3,000-4,000 lbs with the boat & ATV up I-24. In order to get 22 lbs of boots for 2-3 minutes I would guess he would be screaming well over the speed limit to make that happen! IIRC pulling my 5th wheel up that part of the interstate I was barely at 15 lbs of boost at 70 mph.
Your equations make sense an your education is exceptional but the envelope you are working in is approaching the extreme.......
Old Apr 15, 2009 | 02:28 AM
  #139
theenforcer's Avatar
theenforcer
the aussie 7.3 trucks dont have the foil there to remove in the first place, i dont know if they forgot to put it on or just thought it was a **** to begin with..
cheers
josh
Old Apr 15, 2009 | 09:30 AM
  #140
superduty4x4's Avatar
superduty4x4
cheers
josh
Very interesting though that the Aussie models had no foil. How strict are emissions standards in Australia?
Old Apr 15, 2009 | 10:26 AM
  #141
ernesteugene's Avatar
ernesteugene
cheers
josh
I'll get around to replying to "white Buffalo" when I have more time but your observation is too easy a target of opportunity to pass up.
1) If you believe my argument for the foil then you don't have it because your truck doesn't have to pass the EPA city driving loop test.
2) If you believe the argument for the foil that's been cited by Izzy and most others on this forum then Ford thinks that you guys are "tone deaf" and can't appreciate the reduction in turbo whine due to the foil.
Old Apr 15, 2009 | 11:11 AM
  #142
theenforcer
emission standards?
what are they, never herd that word before. LOL
i dont think they are anywhere near as strict as you guys have got it.
Old Apr 15, 2009 | 11:46 AM
  #143
superduty4x4
emission standards?
That would seem to support what Gene has been saying about the foil being added for emissions reason. Very interesting!
Old Apr 15, 2009 | 12:19 PM
  #144
Izzy351's Avatar
Izzy351
Don't forget that "emissions" can mean noise emissions, too. Certain parts of the country have strict rules about how much noise vehicles can produce too. Why do you think they put all that sound deadening stuff on the new trucks now? Out of the kindness of their hearts?
I don't think they're tone-deaf, Gene. I think they don't have as many whiny people complaining about how loud a vehicle is.
Old Apr 15, 2009 | 01:38 PM
  #145
whjco's Avatar
whjco
A little over two years ago, one of the latching tabs broke off of my stock air box. Through this board, I learned about the 6637. I drove over to NAPA, paid about $28 and spent 10 minutes removing the old air box, cleaning the inside of the hose and then installing the original hose over the 6637 using the original clamp. 10 minutes and I was finished and it was a whole lot cheaper than replacing the factory air box.
It's never come loose and the truck has always performed exceptionally well when towing. I'm quite happy with the 6637 mod.
Old Apr 15, 2009 | 01:47 PM
  #146
Izzy351's Avatar
Izzy351
You joined the same time I did, Bill. I found this site because of the CCV mess in my engine bay. Mod'ed that, then put in the 6637, and so on -- my mods are listed chronologically in my sig. See what this site did to me??
Old Apr 15, 2009 | 01:54 PM
  #147
F250_'s Avatar
F250_
Yep, you guys joined up only a couple months after I did as well, but I really did not get active with my participation until about a month ahead of you guys.
Joe, I don't think we're gonna find an end to our thinking alike. I;ve always tried to keep my mods listed in a chronological order as well.
Old Apr 15, 2009 | 01:58 PM
  #148
Izzy351's Avatar
Izzy351
LMAO!!! Pete you and one other member here I've come to find out are SOOO much like me, it's not even funny... Quite scary, actually. Lisa said she noticed it too -- it's like whatever draws a lot of us to these trucks is some kind of common personality trait. Go figure.
Old Apr 15, 2009 | 01:59 PM
  #149
F250_'s Avatar
F250_
Makes me wonder what kind of common stories our wives could tell if they ever got together!!
Old Apr 15, 2009 | 02:01 PM
  #150
Izzy351's Avatar
Izzy351
That I *KNOW* is a scary scenario... Let's try to keep that a minimum...
