trans temp got hot today
Old Apr 6, 2009 | 10:32 PM
Bubba828's Avatar
Bubba828
so i took a trip to the coast today, about 130 mile one way, i had about 800lbs in the bed of the truck. the trans temp on the way there reached about 195 and on the way back i hit 200. nothing too steep on the way over or back. the 200 was when i was on the freeway and it was flat. i stopped and idled for about 10 min and the temp never changed until i started going again and at that point it rapidly dropped to 175 but slowly creeped up the rest of the way home to about 195. do i need to flush my trans cooler? if so, how do i do it?
Old Apr 6, 2009 | 11:21 PM
guzzle92's Avatar
guzzle92
Sounds like your bypass valve may be sticking, not allowing full flow to the cooler.
Old Apr 6, 2009 | 11:35 PM
PaysonPSD's Avatar
PaysonPSD
There is a test procedure at this site for testing the cooler bypass valve. CLICK HERE
Old Apr 7, 2009 | 12:09 AM
Bubba828's Avatar
Bubba828
thats a great "how to" on checking the bypass valve. i will have to check it tomorrow or wednesday if i dont get to it tomorrow. thank you.
Old Apr 7, 2009 | 12:15 AM
PaysonPSD's Avatar
PaysonPSD
Your welcome and I hope it helps diagnose your problem.
Old Apr 7, 2009 | 12:46 AM
Bubba828's Avatar
Bubba828
i read that the bypass valve keeps trans fluid from going to the cooler in order to warm up the trans. can this bypass valve be eliminated and the fluid always go to the cooler, or does it need to be in place for proper operation.
Old Apr 7, 2009 | 01:03 AM
PaysonPSD's Avatar
PaysonPSD
Quote from that site "If you removed it and the cooler were blocked, you'd lose the transmission in a matter of seconds."
Old Apr 7, 2009 | 07:48 AM
Ponyboychris's Avatar
Ponyboychris
I'd suggest that you just replace the bypass line if you determine it's bad.
Old Apr 7, 2009 | 08:59 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That's not what it does. It does not bypass to help warm the trans. It only bypasses if the coolers are plugged. That allows lube flow in the event of a plugged cooler.
Old Apr 7, 2009 | 07:11 PM
Bubba828's Avatar
Bubba828
aaahh it all makes sense now, i see how the whole bypass thing works now. thanks again for the info. i did that test today and it was indeed my bypass valve that is faulty. ford can have it tomorrow and its only $56, so not too bad. the funny thing was when i went in to get the part the guy behind the counter was one of the mechanics. i told him what i wanted and he looked perplexed and said theres no such thing. i of corse said "yes there is" and told him what it was. he dug into the depths of his computer and sure enough there it was. then he asked how i determined that it was the problem and i said that theres an abundant about of knowledge online at a site called ford truck enthusiasts and he should check it out.
Old Apr 8, 2009 | 09:36 AM
superduty4x4's Avatar
superduty4x4
Why would a Ford tech need to know how to fix/diagnose a Ford truck?
Old Apr 9, 2009 | 09:40 AM
Mark Kovalsky
As I think you found out there was nothing wrong with the bypass. The abundant wealth of knowledge on this site has determined that the bypass valve frequently fails. All it has inside is a ball and a spring. It almost NEVER fails.
What frequently happens is that the coolers plug up and then the bypass works as designed and opens up. The only solution at this point is new coolers. You can't flush coolers, it doesn't work.
Old Apr 9, 2009 | 09:43 AM
Mark Kovalsky
Deleted, posted twice.
motocamper
Aug 9, 2012 11:55 AM
1979BEAST
35
Apr 13, 2011 05:40 PM
IceboxFX
29
Jan 19, 2008 10:47 AM
mike333
Feb 24, 2006 10:37 PM
sfitzgerald351
1978 - 1996 Big Bronco
64
Jan 15, 2005 04:27 PM
