flushing the trans cooler
Old Apr 8, 2009 | 04:50 PM
Bubba828's Avatar
Bubba828
how do i flush the trans cooler?
Old Apr 8, 2009 | 05:01 PM
superduty4x4's Avatar
superduty4x4
Stock trans cooler in the rad?
Old Apr 8, 2009 | 05:11 PM
Bubba828's Avatar
Bubba828
well i guess thats another question, is there one in the rad plus the little keyboard one?
Old Apr 8, 2009 | 05:22 PM
Green1995GT's Avatar
Green1995GT
There is one in the radiator and one between the intercooler and radiator. The one on the front is the power steering cooler.
Old Apr 8, 2009 | 05:23 PM
superduty4x4
Yours should only have the trans cooler in the rad stock. The small external cooler was only on the early birds, unless someone has added it.
Old Apr 8, 2009 | 05:33 PM
joegebff's Avatar
joegebff
Gone Fishin for Mark
That requires a mighty big toilet. IMHO you would be better recycling it for scrap.
Why do you feel the need to flush the cooler, or is this to be part of a complete fluid change?
Old Apr 8, 2009 | 05:55 PM
Bubba828's Avatar
Bubba828
the trans is getting warm. i thought it might be the bypass valve but now im thinking it wasnt it and now im out $56, so now its gotta be a plug somewhere. i knew it had a cooler between the rad and intercooler but didnt know about the one in the rad. so how do i go about flushing them both?
Old Apr 8, 2009 | 07:02 PM
superduty4x4
So the late model goes into the rad and then into an external cooler? I thought the late models just used the rad as a cooler.
Either way, disconnect the lines and run some brake-kleen through there (a few cans ought to do the trick).
Old Apr 9, 2009 | 09:33 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The early trucks ('99-mid 2000) only had the air to oil out front, nothing in the radiator. All trucks since mid-2000 have both.
There is NO way to flush a cooler. You can make the trapped particles cleaner with brake clean, but you can't get them out. Some of them will eventually work loose and cause problems in the trans.
The only way to make plugged coolers work is to replace them.
Old Apr 9, 2009 | 09:51 AM
superduty4x4
Learn something new every day... thanks Mark.
