Battery replacement
Old Apr 6, 2009 | 07:59 PM
pony's Avatar
pony
Battery replacement
I have a 2002 F250 5.4. I'm going to replace the battery only because the original is still in the truck and I'm concerned about dependability. Can I just put the new one in? I seem to recall that there is some kind of driving cycle that must be done to re-train the OBDII if battery power is disconnected.
Thanks everybody.
Old Apr 6, 2009 | 10:23 PM
Franklin2's Avatar
Franklin2
You will lose your radio memory, and I am not sure if the radio has a security code or not if the power is disconnected.
And the memory will be wiped out of the engine computer, but it only takes a few hours of driving before it relearns your engine. There is no special procedure for the driving process, just drive it normally.
Old Apr 7, 2009 | 06:29 AM
heymrdj's Avatar
heymrdj
You have about 2 minutes of capacitor charge if you're quick.
Never used it, but supposedly this works well: Amazon.com: Computer Memory Saver: Automotive
Also if you've got the space, you could also always wire in parallel, juggling until you got the hold one out of the loop. Battery Wiring
blackeyed1
6.4L Power Stroke Diesel
19
Mar 29, 2014 10:26 AM
DIYiT
Nov 2, 2010 01:50 AM
imlowr2
1997 - 2003 F150
Oct 17, 2010 05:12 PM
barrett_ross2
1983 - 2012 Ranger & B-Series
Feb 13, 2006 04:59 PM
guerrero101
Jan 30, 2006 11:08 AM
