Battery losing charge
Old Feb 12, 2006 | 10:05 AM
barrett_ross2's Avatar
barrett_ross2
Hi, everyone. I'm having trouble with my battery losing charge. I have a '99 FF 3.0 Ranger with an auto tranny. Two days ago, I noticed that the "low battery" light was on and the needle was dropping on my battery guage in the dash. Yesterday, it dropped below the "L" and my truck died while driving. I replaced the old battery with a new one, but the battery light is still on and the needle is still very low on the guage. I'm wondering if the problem is with the battery cables, or possibly the alternator. Anyone have any ideas?
Old Feb 12, 2006 | 02:13 PM
Hank85713's Avatar
Hank85713
did you get a power team (alt/reg) check after changing the battery? If not go to a checkers of autozone to get them to check for ya. You can go to sears but they will charge for it.
If nothiing else if you have a volt meter try looking for 13.5-15.0 volts when the engine is running. Should be a minimum of 12.5v at the battery with the engine off and when running (although it will not last if thats all it has running).
Clean the posts real good and that might help but they would have to be real dirty to cause the problems you are having.
Old Feb 13, 2006 | 04:59 PM
pawpaw's Avatar
pawpaw
Welcome to FTE
I agree with Hank, run this puppy by your favorite autoparts store, for a no cost electrical system check up, via their portable electrical system tester.
It can properly load test the electrical system, with everything in the vehicle.
From your description of the voltmeter reading, don't be surprised if they find the alternator has problems.
Before you go to check it out, SLOWLY recharge your battery fully, overnight if needed, say at about 4-6 amps.
If the alternator is found to be bad, DON'T put on the new alternator & drive it, with the battery at a low state of charge, as both can be damaged.
The alternator isn't a battery charger.
Having the alternator try to recharge a deeply discharged battery, can cause it to overheat & the batteries plates can be damaged from high amperage from the alternator.
Just some thoughts for consderation.
Let us know what you find.
Barndon
16
Jan 12, 2010 09:14 PM
dbuck50
Dec 22, 2009 01:04 PM
hrsetrdr
1997 - 2003 F150
21
Apr 29, 2009 11:40 AM
swandog
Jun 29, 2005 08:46 PM
LittleRedPSD
Oct 8, 2004 10:08 PM
