cab swap wireing issue
Old Mar 31, 2009 | 08:35 PM
ryan f150 4x4's Avatar
ryan f150 4x4
i am replaceing the cab on my 92 f150 and the cab i got is off a 94 its auto mine is 5speed . the prob is after i bought the cab the guy at the junk yeard sold the steering colem and let the guy pull it himsalf and he cut the plug off the wiring can i graft my plug to new cab or change the hole thing
Old Apr 1, 2009 | 07:06 PM
Franklin2's Avatar
Franklin2
Didn't the steering column in the 94 have the wipers, etc. on the turnsignal stalk, and the 92 doesn't? I am not sure, but there may be enough differences were you will have to use your 92 column, and all the other wiring from the 92 to make it work.
Old Apr 2, 2009 | 05:36 PM
ryan f150 4x4
the callams the same but mines a stick and the new cab had an auto tranny
Old Apr 7, 2009 | 11:47 AM
ryan f150 4x4
someone has to know come on guys i need ur help !
Old Apr 7, 2009 | 12:49 PM
Franklin2's Avatar
Franklin2
You have your wiring harness from the old cab, and it has a all the plugs correct? And you have the new cab, and it has a bunch of wires that have been cut off. If you count the number of wires on your old wiring harness, and that is the same, and all the wire colors match, then I would say it would work. Any color differences or the number of wires being different would stop the show.
