Thanks. I had the Autozone clerk write it down and those were the numbers. I guess I'll try another store.
I thought I'd take off the Throttle body and clean it to see if I could make it go away. In the process I broke one of the bolts (10 MM - not the long one with the fitting). Can I replace it with a steel bolt from Lowe's or is there a special type/hardness/thread I should use for this?
