ZF-5 speed for 96 deisel
<TABLE style="BORDER-COLLAPSE: collapse" borderColor=#111111 cellSpacing=0 cellPadding=2 border=1><TBODY><TR><TD colSpan=7>
</TD></TR><TR><TD>Make</TD><TD>Transmission</TD><TD>1st Gear</TD><TD>2nd Gear</TD><TD>3rd Gear</TD><TD>4th Gear</TD><TD>O/D</TD></TR><TR><TD>Ford</TD><TD>T18/19 (diesel)</TD><TD align=middle>4.02</TD><TD align=middle>2.41</TD><TD align=middle>1.41</TD><TD align=middle>1.00</TD><TD align=middle>N/A</TD></TR><TR><TD> </TD><TD>T18/19 (gas)</TD><TD align=middle>5.11</TD><TD align=middle>3.03</TD><TD align=middle>1.79</TD><TD align=middle>1.00</TD><TD align=middle>N/A</TD></TR><TR><TD> </TD><TD>ZF5 (diesel)</TD><TD align=middle>4.14</TD><TD align=middle>2.37</TD><TD align=middle>1.42</TD><TD align=middle>1.00</TD><TD align=middle>0.76</TD></TR><TR><TD> </TD><TD>ZF5 (gas)</TD><TD align=middle>5.72</TD><TD align=middle>2.94</TD><TD align=middle>1.26</TD><TD align=middle>1.00</TD><TD align=middle>0.76</TD></TR><TR><TD>GM</TD><TD>SM465</TD><TD align=middle>6.56</TD><TD align=middle>3.58</TD><TD align=middle>1.70</TD><TD align=middle>1.00</TD><TD align=middle>N/A</TD></TR><TR><TD> </TD><TD>NV4500</TD><TD align=middle>6.34</TD><TD align=middle>3.44</TD><TD align=middle>1.71</TD><TD align=middle>1.00</TD><TD align=middle>0.73</TD></TR></TBODY></TABLE>
The ZF S5-42 is built in both a 2 wheel drive and 4 wheel drive version with gas and diesel designs
ZF first introduced the S5-42 in 1987 and was used in the Ford F250, F350, F450 and Super Duty trucks until 1994.
All gears on the S5-42 are fully synchronized with an input torque rating of 420 ft-lb
Standard gear ratios on the ZF S5-42:<TABLE cellPadding=0><TBODY><TR><TD><TABLE cellPadding=0 width=166><TBODY><TR><TH scope=col colSpan=2>Close Ratio </TH></TR><TR><TH scope=row width=85>
The ZF S5-42 main case cast number is “1307”
_______________________________________________
The ZF S5-47 is built in both a 2 wheel drive and 4 wheel drive version with gas and diesel designs
ZF introduced the S5-47 in 1995 and was used in the Ford F250, F350, F450 and Super Duty trucks.
All gears on the S5-47 are fully synchronized with an input torque rating of 470 ft-lb
Standard gear ratios on the ZF S5-47:<TABLE cellPadding=0><TBODY><TR><TD><TABLE cellPadding=0 width=166><TBODY><TR><TH scope=col colSpan=2>Close Ratio - 7.3L Diesel </TH></TR><TR><TH scope=row width=85>
The ZF S5-47 main case cast number is “1317”
You can see that they lowered the gearing for the PSDs as their torque peaks later. Running a S5-42 behing a PSD would not be good choice IMHO.
I have a S5-42 behind my 6.9 IDI and while is works great, I wish I had lower gearing for trailering.
My 97 PSD has the S5-47 and the lower gearing is real nice, but lower would be even nicer. I have been toying with the idea of swapping the gears or whole trans from a gasser to get the lower first, but the wider steps in the other gears may be too much. Our engines redline around 3400rpm while the gassers are around 4500. Runnind the gasser ratios would require you to rev close to redline and then drop fairly low down in the next gear.....maybe too low. I would do the math, but feeling lazy.....
i've got the '92 7.3idi, e4od (broken), 4.10 gears.
got a parts truck i just found for a real good price, has the 460 with (i'm assuming... gotta take a drive tomorrow to see it) the zf-s5-42.
have you confirmed whether or not the zf from the 460 will bolt onto my 7.3 diesel?
repeated searching all over the internet has led me to some guys saying "there's no way it will fit" to "they're the SAME tranny with different gears"
this parts truck would be ideal, as i'll be needing the new pedals and clutch, m/s cyl etc etc.
i dont plan on doing any heavy towing either, so the "redline to stall" shift issue shouldnt be too bad i'm hoping, especially with the 4.10s.
HELP!! heh heh, i'll be taking the drive in the morning hopefully so any quick input would be great!
thanks!
I will have a look at my spares today and compare them. I believe that the spacer/adaptor between the engine and trans has the big ford pattern on the trans side......
