hpop ?
Old Apr 1, 2009 | 06:03 PM
arkredneck's Avatar
arkredneck
hpop ?
what are some symoptoms of a hpop getting weak? and could stage II's cause one to get weak faster?
Old Apr 1, 2009 | 06:17 PM
1dieselman's Avatar
1dieselman
From what I understand a stock hpop can be iffy for stage IIs to begin with.
Old Apr 1, 2009 | 06:56 PM
BlueMule's Avatar
BlueMule
No! They pump the same amount of oil no matter what injectors you have.
15* pumps can barely keep up with 160's, if you have 180 stage II's it'll be even worse
Old Apr 1, 2009 | 09:05 PM
rideracelivemx7's Avatar
rideracelivemx7
Well I would imagine that a weak pump sign would be inconsistent idling or rough idling and surging, but when you have 2's the engine falls on its face at high rpms, it runs out of oil on top end and throws a code till you restart
Old Apr 1, 2009 | 09:16 PM
BlueMule's Avatar
BlueMule
If the light bothers you you can just turn the key off and on again while you're driving.
Old Apr 2, 2009 | 10:00 PM
oldbird1965's Avatar
oldbird1965
I just use a piece of black tape over it, lol.
Old Apr 3, 2009 | 06:37 AM
MADVAN's Avatar
MADVAN
Glenn
Is your 17* pump a reman or OEM?
Bill
Old Apr 3, 2009 | 10:13 AM
arkredneck's Avatar
arkredneck
could a weak hpop cause the truck to surge and idle bad at start up and clear up a min or so after idling?
Old Apr 3, 2009 | 11:46 AM
oldbird1965
Originally Posted by MADVAN
Glenn
Bill
reman pump
B_Allen
Oct 10, 2013 04:54 PM
robinsonpowerstroke
20
Apr 24, 2012 06:33 AM
1950gmcelc
Jan 30, 2010 11:27 AM
Orezona
28
Oct 27, 2009 04:53 PM
KevinC.
23
Apr 4, 2009 05:29 PM
