hpop?
Old Jan 29, 2010 | 01:18 AM
1950gmcelc's Avatar
1950gmcelc
hpop?
Hey guys so my truck is still died after installing injectors. I am starting to wonder if maybe my HPOP is weak or mad or if my IPR is bad. How can I test to see if either of these are bad or weak. Would either a bad or weak Hpop or a bad IPR cause the truck to die and then not start?
Old Jan 29, 2010 | 08:08 AM
Action4478's Avatar
Action4478
You can isolate the pump & the IPR with a gauge ...
Here is what is needed to put a gauge together thanks to Swamps site.
If you don't have access to a scantool, then go to your local hydraulic supply
house, and have them make you up a mechanical gauge. You might spend $60
or so on high pressure hose, fittings, and a quality 0-3500psi liquid filled
gauge....but having this hose available for future diagnostics might be more
valuable than you think.
The hose which you will need will need to be about 40" long, rated for
(minimum) 3000psi working pressure (12k psi burst rating!) with the gauge on
one end, and a #6 female JIC swivel fitting crimped onto the other.
You will also need an individual fitting to screw into the head to go from the
head to the hose.
This single fitting will be a 90degree fitting # 5 "male boss" (sometimes called #
5 o-ring) on one end of the 90, and a # 6 male JIC on the other end of the 90.
Our local hydraulic shop would label such a fitting as 5MB-6MJ90
"JIC" is nothing special...it's just 'hydraulic talk' for a 37degree flare
fitting...standard hydraulic stuff here...nothing rare by any stretch.
Looking at the top of (either) cylinder head, you'll see the factory stainless
braided oil lines (one to each head) then you'll see a few bronze colored
plugs... (Engine off, of course) Using a 5/8" wrench, remove any one of the
bronze plugs, and install the 90deg fitting into the hole. (save the plug for
reinstallation , after testing). and the O-rings are reusable, unless brittle,
cracked, etc...
The single 90deg fitting will have a "jamb nut" on the O-ring side...screw the
fitting into the head, "aiming" the 90 away from the turbo, intercooler pipes,
etc...and then tighten the jamb nut, to "squish" the O-ring also locking the 90
from "spinning" around as you attach the swivel end of the hose to the 90. No
sealants, loctite, or teflon tape are needed on "JIC" or O-ring fittings...and
don't overtighten them...usually about 180degrees with a wrench past finger tight.
Old Jan 30, 2010 | 01:50 AM
1950gmcelc's Avatar
1950gmcelc
Thanks for the great right up I'll try to get the parts together to build the gauge. I will see what happens in the morning. I have a guy coming over to run a scan on the truck from what I had told him over the phone he was guessing hpop. Is there a good pump you guys recommend? I was looking at the Deisel Site adrenaline pump but I don't know.
Old Jan 30, 2010 | 10:14 AM
nateairman's Avatar
nateairman
Great write up on the gauge build. Will try to get it done today!
Old Jan 30, 2010 | 11:06 AM
oldbird1965's Avatar
oldbird1965
I have the adrenaline from Dieselsite, great pump!
Old Jan 30, 2010 | 11:27 AM
Action4478's Avatar
Action4478
It could still be the IPR , as well...
farmall99
16
Mar 20, 2026 03:14 PM
cabloom300
Mar 22, 2019 10:00 AM
cope1972
Sep 22, 2014 06:51 AM
exiled
Mar 11, 2014 07:08 AM
89ford73
Feb 15, 2009 09:33 PM
