ebpv oil leak
Old Apr 1, 2009 | 03:59 PM
stephen.south's Avatar
stephen.south
ebpv oil leak
My truck in bleeding oil, after a couples hours of tracing upward, I found that the ebpv is leaking. It was a slow leak ( 1 gallon of oil in 5 hrs) but now it poured out a gallon in 5 mins. It is coming from the push rod from the ebpv. Am I gonna have to replace the whole pedesal? It doesn't leak right away, but I can watch it as I start it up and see it only leaks once the ebpv opens.
Old Apr 1, 2009 | 05:22 PM
1dieselman's Avatar
1dieselman
What most guys do is delete the ebpv actuator. I think that Ron's turbo service has a modified pedestal for sell or IH used a different pedestal also. I believe you can use a pedestal from a 94 powerstroke because they supposedly didn't have the ebpv installed. There is a rebuild kit available but pricey and most of the time the aluminum housing is scored beyond use.
Old Apr 1, 2009 | 07:07 PM
84-250's Avatar
84-250
1dieselman: my 94.5 PSD has a EBPV
stephen.south: you can gut the EBPV or buy a non EBPV pedestal
Old Apr 1, 2009 | 07:17 PM
1dieselman's Avatar
1dieselman
Is yours considered a 95? One that I recently worked on which is a 94 has never been modified or anything and does not have a ebpv installed.
Old Apr 1, 2009 | 07:24 PM
84-250's Avatar
84-250
1dieselman: doubt it; truck built 5/94, engine built 5/23/94, engine serial number is between 20k and 23k
Old Apr 1, 2009 | 07:37 PM
1dieselman's Avatar
1dieselman
Huh, strange, I wonder why there isn't one on this engine, I've heard of a couple of others all stock with no ebpv installed but didn't see it first hand. I don't know what the build date on this truck but it's got me curious.
Old Apr 1, 2009 | 08:12 PM
blake 7.3L's Avatar
blake 7.3L
You can also remomve the gutts and the rod and tap and plug the hole. This is the easiest and cheapest option.
Old Apr 2, 2009 | 02:17 PM
stephen.south
Ok, thanks, I found the rebuild kit on diesel site and just ordered it, since I do go up north sometimes in the winter.
Old Apr 2, 2009 | 05:54 PM
84-250's Avatar
84-250
stephen.south: I live in cleveland ohio and my truck runs fine without the ebpv. unless you're going farther north.
Not to hijack this thread but can the oring on the other side of the ebpv rod be changed? The one behind the 1.5" cover thats held in by a snap ring. Can it be changed with the turbo and pedistal on the truck?
Old Apr 2, 2009 | 06:06 PM
1dieselman's Avatar
1dieselman
It can but you had better take a double dose of patience. I did it like that once, I think I'd rather pull the turbo next time.
Old Apr 2, 2009 | 06:14 PM
84-250's Avatar
84-250
1dieselman: Is it a ford part or just a std oring?
Old Apr 2, 2009 | 06:50 PM
1dieselman's Avatar
1dieselman
It is a brown viton o-ring and pretty small thickness. I wouldn't be holding my breath about finding it at the local hardware store or parts house. I would check with Ford first.
Old Apr 3, 2009 | 03:30 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
The kit <TABLE style="BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=2 width="100%" border=0><TBODY><TR><TD class=ProdDisplay1>1994-2003 7.3L Turbo Pedestal Rebuild Kit </TD><TD class=ProdDisplay1 align=right><INPUT id=strProductPartNumberBase type=hidden> </TD></TR></TBODY></TABLE>on diesel site, at the end has a NOTE: If Oil is dripping from the EBP piston rod housing ....the entire pedestal assembly must be replaced
Old Apr 3, 2009 | 03:36 PM
1dieselman's Avatar
1dieselman
That's why I stated above that most of the time the housing is scored beyond use.
Old Apr 3, 2009 | 08:42 PM
fridgeddiesel's Avatar
fridgeddiesel
I live in an extremely cold climate (coldest in the lower 48) and I gutted mine years ago. It is so cold here I used to have the epbv get stuck closed at -30* or colder. Runs much better with it gone, no more loss of power, no more sticking, no more oil leaks. The only down side is that it takes 10 miles or so of driving for the heat to come on in the cab. I don't really care - I work outside year round and am dressed for the cold. At night the truck is parked in a heated garage and ready to go - warm in the morning. I think the epbv was one of the worst things Ford placed on the 7.3L Diesel.
JJD
Aug 1, 2016 11:01 AM
Karruda
Nov 16, 2015 10:39 PM
Liquid10Rider
Dec 11, 2012 04:58 PM
timmyboy76
Mar 16, 2011 07:57 PM
Groundpounder0331
Jun 2, 2009 09:25 PM
