411 code 96 f150
Old Dec 30, 2010 | 02:52 PM
droppedf100's Avatar
droppedf100
Ok I rented the vacuum tool. One of the AIR valves pulls vacuum after I start it up but the other does not. I checked power to both with a test light and they both are getting power. The solenoid that doesnt pull vacuum is E7TE 9H465-BA. Should I replace it and where is the best place to get one?
Old Dec 30, 2010 | 04:12 PM
subford's Avatar
subford
Did you check to see if it pulled vacuum by grounding the non-red wire at the solenoid with vacuum applied to the solenoid?
Old Jan 2, 2011 | 01:06 PM
droppedf100
No I didnt check but I swapped one from a friends truck that weren't functional and it tested good. It has been just under 100 miles and no CEL so it should pass on monday. Thanks alot for all your help you made pinpointing the problem pretty easy.
Old Jan 3, 2011 | 05:52 PM
droppedf100
130 miles and still off. Thanks again. Talk to you in 2 years lol.
tvliftcabinet
Feb 3, 2017 03:25 PM
akpolaris
Jan 15, 2017 11:02 PM
hot-rod
Aug 19, 2016 07:25 PM
swellman
Apr 23, 2016 06:04 PM
MAC012382
Aug 27, 2006 01:14 AM
