finally got pyrometer installed
Old Mar 29, 2009 | 11:54 AM
  #46
galute's Avatar
galute
That is true only to a certain point. That point is where the amount of fuel exceeds the amount of air available to burn it. A N/A engine has a fixed amount of air it will draw into it at any given rpm. Once the amount of air needed to burn the fuel is exceeded then the result is unburned fuel (excessive black smoke). Unburned fuel does not produce heat, it actually cools the exhaust temps the same way water injection does, hence the cold exhaust temps. It is possible to reach high EGT's and still blow black smoke but only if you have enough air available to burn enough of the fuel to create the heat. That's why I said turn the fuel back to a more effiecent burn and the temps will come up.
A turboed engine is whole nother ball game. The more fuel you put to it the more boost it makes. The more boost it makes the more air into it. The more air into it the more fuel burned. The more fuel burned the more heat it makes and on and on till it melts itself.
There is no difference between gas and diesel. They both require the correct amount of air to burn properly. Without air, neither will burn at all.
Old Mar 29, 2009 | 01:27 PM
  #47
dyoung14's Avatar
dyoung14
another thing i forgot to metion, i installed a aftermarket water temp gauge, my truck never gets above 160 degrees, weather im driving on flat ground or comming up a mountai, think that has anything to do with it?
Old Mar 29, 2009 | 02:23 PM
  #48
galute's Avatar
galute
It very well could be part of the problem. Everything about these engines affect EGT's. Operating temps, outside air temps and the amount of air going in, fuel temps and the amount, humidity, elevation. Just to name a few. The possibilities are mind boggling sometimes.
Old Mar 29, 2009 | 03:08 PM
  #49
Dave Sponaugle's Avatar
Dave Sponaugle
Big difference between a gas and diesel engine, namely throttle body on the gasser.
A gasser controls the amount of air with a throttle body and the amount of fuel by either injection or carbeuration.
So in a gasser, you can have lean and rich conditions.
Since an IDI diesel has no throttle body, the only thing that changes is the amount of fuel injected to control engine speed.
Rich and lean by gasoline engine standards is controlled by your right foot.
The fuel to air ratio is constantly changing as per your foot's request for more or less engine speed.
Can the engine run to lean?
No, if there is not enough fuel the engine will not run.
Can you inject to much fuel, most definitely.
Will it harm the engine, most definitely with either excessive soot or in extreme conditions fuel dilution of the oil and washed out lubrication for the rings.
Yes, you can inject enough fuel that it will cool the EGT's and lower power.
Old Mar 29, 2009 | 03:19 PM
  #50
dyoung14's Avatar
dyoung14
i have absolutley no idea what to do, i guess i will just have to buy a new pyro and set my turbo project back even farther
Old Mar 29, 2009 | 09:05 PM
  #51
harleyjohn45's Avatar
harleyjohn45
dyoung says he has good power. Pulling hills in top gear, that impresses me with a NA engine smoke or no smoke.
Old Mar 29, 2009 | 09:12 PM
  #52
harleyjohn45
The extra fuel is probably cooling the egt's. Once you add your turbo, you will know for sure. You may not have to even adjust fuel to have a fine running engine. The guage is probably correct.
Old Mar 30, 2009 | 01:14 PM
  #53
dyoung14's Avatar
dyoung14
it impresses me too, my dads 7.3 sure wont do it, i guess its just something to do with the mods it has and i guess the fuel system is in good shape and it has the timing is just right and fuel turned up just right, but yea my dads truck wont keep up with mine at all
Old Mar 30, 2009 | 01:27 PM
  #54
88f150302's Avatar
88f150302
ok i found a 3 guage pillar pod with trans tem pyro and boost guages for 199 shipped to my door is that a good price? i dont really need the boost guage but i could put it in just to look cool haha
Old Mar 30, 2009 | 03:23 PM
  #55
dyoung14's Avatar
dyoung14
yea i think that would be a good deal, and you already got the boost gauge if you ever get a turbo
Old Mar 30, 2009 | 03:34 PM
  #56
88f150302's Avatar
88f150302
i have been looking at pyros and they are all over $100 new so i thought it was a good deal
Old Mar 30, 2009 | 04:18 PM
  #57
444dieselrod's Avatar
444dieselrod
Umm. NO. more fuel means more heat in a diesel plain and simple. NEVER EVER will adding more fuel cool the exhaust its just not possible. Black smoke is unburned fuel, we all agree on that. but black smoke will never cool your exhaust just limit the amount of power you will put to the ground only MORE air, be it boost, intercooled air, or NO3, will cool your exhaust.
No where in this thread has anyone asked what kind of pyro you have and how the probe is connected to the gauge. is it a thermocouple type that has no outside power source or do you have to supply power to it from the fuse box?? does the probe connect with a snap type coupler or does it have 4 eyelets that you put the tiny bolt through and tighten down??
Diesel Rod
Old Mar 31, 2009 | 07:43 AM
  #58
dyoung14's Avatar
dyoung14
Diesel Rod
it is a thermocouple type gauge, no outside power source
Old Mar 31, 2009 | 01:15 PM
  #59
starmilt's Avatar
starmilt
dyoung if your heat guage is correct and your motor is truly not getting over 160 degrees you will not get optimum fuel burn. She needs to run 195 to 200.
Old Mar 31, 2009 | 03:23 PM
  #60
dyoung14's Avatar
dyoung14
im thinking about getting a new thermostat to put in it, but aint they a pita to change?
